harrypodder
Topic: drain caps Posted: 23 Oct 2019 at 4:14pm |
D
crw8sr
Posted: 23 Oct 2019 at 4:55pm |
Don't know that, but I went to Menard's and purchased pvc shut off valves and screwed them on. Work great.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
marwayne
Posted: 23 Oct 2019 at 8:53pm |
Just put on some shut off valves.
harrypodder
Posted: 24 Oct 2019 at 5:28am |
I appreciate the suggestion of drain valves which I would consider but I travel during freezing weather and any piping extended and exposed to the elements is subject to freezing. My drains are tight up against the underbelly board to lessen the chance of ice up that is why I use the caps.
riotkayak284
Posted: 24 Oct 2019 at 9:25am |
I found them on Amazon.
https://www.amazon.com/Flair-16860-Plastic-Fitting-Size/dp/B000H602C8/ref=sr_1_4?crid=1CDRHQZ3ALBQ5&keywords=rv+water+line+cap&qid=1571927112&sprefix=rv+waterline+%2Caps%2C145&sr=8-4
crankster78
Posted: 24 Oct 2019 at 6:32pm |
Greetings: Find a local RV dealer. They should have them. I found them at mine. They are inexpensive so buy a few to have. It's pec pipe, a Home Depot, or Lowes might have them.
Crankster78 R-179
Crankster 78 R-179 2015
Posted: 25 Oct 2019 at 3:46pm |
I would take one to Lowes or Home Depot, agree they are PEC.
Posted: 26 Oct 2019 at 7:46am |
To clarify the plumbing in rPods is half inch PEX tubing. PEX is great to work with and the most common plumbing system used these days. You can get push on fittings (Sharkbite is one brand) or you can get clamp fittings and a clamping tool. Either are available at any big box hardware place.
crankster78
Posted: 26 Oct 2019 at 7:59am |
Greetings: Sorry I meant PEX senior moment
![Ermm Ermm](smileys/smiley24.gif) Crankster78
Posted: 26 Oct 2019 at 10:15am |
![Ermm Ermm](smileys/smiley24.gif) Crankster78 |
I blame those on a keyboard malfunction. The C is just to the right of the X on the keyboard, so the keyboard is at fault. ![Wink Wink](smileys/smiley2.gif)
