Well, got started between rain drops.. So far I haven't located/comfirmed the line back from the TV to the panel area. What I did find was a bit disappointing..
Now, I have read some pretty good arguments that there can be logic to chaos.. One of those believers wired my trailer! What a rat's nest of wires!
Worst are these two wires.. If anyone can identify, please do..
This one comes out of the DC side of the panel box. End is flatten like it was connected to something..
This one looks like it comes out of that red whatever (some sort of fused splice I think) but it actually passes under that and runs back into the abyss of wires.. Again, flatten end like it was connected somewhere.
Next is what I believe to be the Converter charger return. And yet another of those auto breakers hidden away never to be found by the average consumer..
In that last picture you see two wires on a side and the single that is running the the panel box. I need to ring both these out, but I think this is the 7 pin and the battery cable meeting up. If this is so, it explains another fuse here before the panel. And if indeed so, that makes the DC side 30amp max, at least from TV or battery.
Lastly, I was hoping to find the Converter/charger was a separate unit from the panel. Not going to be that easy.. It's integrated. I'll read some more on the repair to the WFCO that another member (here?) posted and possibly reach out to see if a switch can be installed. A bit more time required on this part.
Most important right now is if anyone can identify those loose wires?
