Topic: Stainless steel screwd Posted: 09 Apr 2020 at 9:23pm |
What?? ![Shocked Shocked](smileys/smiley3.gif) No moisture in Nevada??? Why it's raining right now. Only we need a whole lot more as does CA.
I enjoyed the excessive salting of the roads in NJ, having lived there 10 years and have seen the results on every kind of structure made my man or bird. It's awful. I agree, where you have that kind of corrosion potential 316 SS screws make sense. It's really frustrating to see the results years later. A perfect screw, with everything around it oxidized or corroded, the screw hanging by a "thread." Personally, I tried to take my car to the car wash after every snow storm to rinse the salt off top and bottom. If I had a trailer there, I don't think I'd take it out on salty roads, though that can't always be avoided.
Even here we have salt issues. Both times our trailer has been out this year, it got a salt bath on the way home from melted snow and salt. Now, it's just sitting, and sitting, and sitting.... along with the new truck to pull it. NO! I don't have cabin fever! I'm just feeling cramped. Maybe I should take my mask off at home?
Posted: 09 Apr 2020 at 3:56pm |
Rust is common to all screws made of steel when there is moisture available. I have had 2 FR trailers and they don't seem to be out of the ordinary, insofar as rust is concerned. If the screws are rusting where there should be no moisture, it's an early warning sign that water is getting into where it shouldn't. Parts of the screws that are exposed to the outside will normally show some rust if not powder coated or painted. If the shafts of the screws are rusting, you may want to try to figure out where the moisture is getting in and fix it. If it's coming in through the screw hole, then take the screw out, coat the threads with marine sealant caulk, and replace them. If it's coming in through some other source, then you'll need to track it down. |
He he. You live in NV where there is no moisture to speak of.
If you live in the Southeast or drive in the winter in the Rust Belt its a different story. Moisture is everywhere, and everything in those areas rusts. It doesn't necessarily mean that moisture is getting in where it shouldn't (although it could be). SS screws are a great idea, but mild SS (like 304 aka 18/8) will rust too, often badly. 316 is the good stuff, although its more expensive. That's what I'd recommend especially if you're going to be exposed to road or sea salt.
EchoGale
Posted: 09 Apr 2020 at 2:29pm |
Same.
Julie
Posted: 09 Apr 2020 at 12:42pm |
Posted: 09 Apr 2020 at 11:25am |
+2 on the Slayer. Yup, that was Zuck’s nickname at his Hahvahd frat house.
tcj
Posted: 09 Apr 2020 at 10:46am |
So is corrosion of screws in an Rpod a common issue?
2018 R-pod 180 Hood River Edition
tcj
Posted: 09 Apr 2020 at 10:44am |
Zukerberg will own your soul.
Posted: 09 Apr 2020 at 10:20am |
+1 to Glue Guy.
Posted: 09 Apr 2020 at 10:03am |
Originally posted by Jeepinator
You may need to be a member of the RPod Ownere group on Facebook to access this - https://www.facebook.com/groups/RPodOwners/permalink/10156315531555808/
It’s very detailed on replacing the screws |
Yup. Closed group. I can not in good conscience join FB.
Jeepinator
Posted: 09 Apr 2020 at 9:14am |
2018 Jeep Wrangler Willys
2017 179
