Furrion Stereo Antenna Connection? |
Post Reply | Page <12 |
Topic: Furrion Stereo Antenna Connection? Posted: 03 May 2020 at 5:07pm |
Amazon is a good place to look. That is where I purchased my replacement.
KB7LAK
Newbie Joined: 12 Mar 2020 Location: UT Online Status: Offline Posts: 10 |
Posted: 03 May 2020 at 5:14pm |
I saw they had one for $22. Guess I'm going to have to go that route.
2019 RPOD 172
2012 Yukon XL |
Posted: 03 May 2020 at 6:07pm |
Good! That is a lot less than I paid for my replacement. I have the older Jensen system and after breaking two of the bat-wing antennas, replaced it with a flying saucer. There are pictures somewhere in my mods, but I couldn't say which page.
KB7LAK
Posted: 03 May 2020 at 6:48pm |
It's a whip antenna. I was wondering why it wouldn't do the channels. No antenna!
2019 RPOD 172
2012 Yukon XL |
Buffalohunter
Groupie Joined: 12 Oct 2019 Location: Bellingham, Wa Online Status: Offline Posts: 57 |
Posted: 06 Jul 2020 at 5:45pm |
I too have the “rabbit ear” antennae that feeds the tv...with an amplifier, I guess, that is on all the time. There is no outlet with a switch near the tv. Over the bed there is a switch plate where a tv could go. It says cable or satellite...the switch is off, no tv there. So the only tv is right as you walk into the pod. Above the tv is a enclosed wall/ceiling mounted station with face plates for the solar panel, the radio and the control panel for the slide, awning, lights. On the tv wall, just below this instrument cluster, is a gfci outlet, the inverter switch, a USB port and the tv. All wires run from the tv into a hole where the above mentioned face plates are located. Where am I missing the switch for the amplifier in the antenna? I am tired of seeing the red light on this antenna continuously lite. so how do I cut power to that antenna? There is no access to the boxed in instruments mounted on the wall just up against the ceiling above the tv. All I get is a continuous snow of busted up styrofoam from the wire hole into the wall mounted instrument station anytime we take a trip. Just trying to get qualified on this rig...thanks for any help.
R-pod-2020 189
2013 Toyota Tacoma |
