10 year old R-Pod Maintenance |
Post Reply | Page <12 |
Topic: 10 year old R-Pod Maintenance Posted: 03 Jun 2020 at 11:10am |
Grant, you should be able to run the air conditioner at home on a 15A or 20A circuit to test it, as long as nothing else is on in the trailer, including shutting off the battery charger/converter using its circuit breaker. Also be sure the water heater element is shut off. There are two ways to do that, there is a switch hidden toward the bottom left inside the outside water heater access door and there is a dedicated breaker for it in the panel.
Since you can burn the element out if there is no water in the water heater its best to always leave it off unless you are actually going to use it. Have you tested it and the gas water heating? They are independent systems so can be used either separately or together, but test them separately.
A couple other suggestions for a 10 year old unused trailer to be sure things are working: Have you confirmed that the battery charger/converter works and charges the battery when its on and plugged in? You can best do that with a voltmeter, it should show a battery voltage over 13 if the battery is fully charged and the converter is working. Have you set up the brakes on your brake controller and know they are working correctly on both sides? If you use your controller (not your tow vehicle brakes to gently stop the rig a few times from around 35 to 40 mph both drums should be hot but not smoking hot. Vent fan works and cover opens and closes OK? No water leaks anywhere inside or out? Outside shower works? As StephenH says. be patient with these absorption fridges. They have ammonia in them as the refrigerant and will slowly corrode from the inside even when not being used. They have a useful life of around 10 years give or take a few, so you might want to budget for a new fridge before too long. |
Grant177
Groupie Joined: 15 Mar 2020 Location: Edmonton, AB Online Status: Offline Posts: 65 |
Posted: 03 Jun 2020 at 10:34am |
Thanks for the comments Stephen...
The gaps in the slide are really only underneath where the mechanical track is....I'll try take a picture later today. Yes, the R-Pod is perfectly level. It was on AC at the time (though I have tested the propane as well), and running all the lights on the temperature....(the "bigger" snow flake) which I am sure is more cold. I'll try get a temperature and/or make some ice cubes as a test later on. I'll report back...
Grant
2011 R-Pod 177 |
Posted: 03 Jun 2020 at 10:18am |
I'll start in reverse order. Slide-out seals need to be conditioned. Protect-All Slide-Out Rubber Seal Treatment is what I use. It provides UV protection as well as reducing friction. Also, you can look at the inside lip of the slide-out to see where the gaps are. You might be able to install some weatherstripping to help close up the gaps. I seem to be very attractive to mosquitoes so I like to keep them out also. I have a small bug-zapper flyswatter that is useful for those few that do get in regardless of all attempts I make to keep them out. Window seals: Addressed in the other post. Refrigerator: Is your RPod level (or very nearly level)? This type of refrigerator needs to be close to level for it to work properly. Are you running it on AC? DC? Propane? That would help in the diagnosis. What setting do you have it on? The lights are reverse of what you might think. The setting is more bars = cooler and less bars = warmer. Also, these take a long time to cool. It can take a day or longer for it to get down to proper temperature. If the ambient temperature is very high, don't expect it to be able to overcome that easily. If the sun is shining on that side of the trailer, it will not help at all. Check the refrigerator's burner if you are using propane. Is it a clear, steady flame? Is the flue clear? Even if it was not used much, the jet may need to be cleaned and/or the burner itself may need to be cleaned. Make sure no spiders or wasps have been building webs/nests in there. Have you taken a thermometer and put it inside the refrigerator? The freezer compartment to get actual temperatures? "Not that cold" is not very precise. It helps to know if it is reaching proper freezing and refrigerator temperatures. Putting an ice tray in the freezer can let you know if it is getting cold enough to at least freeze the water. If the refrigerator is getting down to below 40F, that is not too bad.
Grant177
Posted: 03 Jun 2020 at 9:38am |
So, the history of my R-Pod is a bit of an unknown and I'm looking for suggestions for anything else I should be "testing" before heading out on a real camping trip. It is a 2011, but is literally brand new. I bought it at an auction last fall and never had a chance to touch it before winter hit, so this spring is the first we've used it and we are getting ready to go on our first camp next week. Interestingly, there was not a single sign of wear or use anywhere. The steps, tires - everything...not the slightest scuff mark etc. Looked like a brand new, 10 year old trailer. I could not even get the safety pin in the hitch...paint was still in the hole. So, in reality, it looks like someone purchased it, then never used it, and it sat for 10 years....really hard to say. As you may have seen in my water pump "help" thread, doing an at-home "test" run exposed a problem withe water pump system which seems to be resolved now. Anyways, so far, I've done the following:
We'll test the AC when we go camping next week (though we will not need it here) as I don't have 30A power at home to turn it on. Some things I've noticed (which I am not sure I can do anything about)
What else should I be looking for or doing? |
Grant
2011 R-Pod 177 |
