Kitchen sink fell |
Post Reply | Page <12 |
Author | ||
Topic: Kitchen sink fell Posted: 22 Jun 2020 at 7:40pm |
Posted: 22 Jun 2020 at 7:45pm | |
You're not the first one to have an undercounter sink in an rpod fall down. There have been multiple instances. So, I think its the normal practice at FR. You can't develop any reliable pull out strength in fiberboard, no matter what size screw you use. The material has no ability to take tension stress, it just pulls apart, plus it swells to 2x it size when it gets wet. The older models are surface mounts so don't have that problem. Under mount sinks seem to be the latest fad in home kitchens so FR is trying to imitate that in their trailers but using the wrong materials. Some new things aren't better. This is one of them.
Posted: 23 Jun 2020 at 2:16pm | |
SH - it is tiny and could very well be plastic, but it's not falling in :)
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
Posted: 23 Jun 2020 at 7:41pm | |
With our 2009 r-pod and our 2012 Vibe one of the first things I did was replace the kitchen mdf counter tops with Baltic Birch plywood and the plastic sinks with larger stainless steel sinks. Thankfully our Vista was built with a plywood counter top and just replaced the plastic sink with a larger stainless steel sink. Still liked some of the construction in our 2009 r-pod the entire dinette was framed with quality hardwood something they changed in the later years building the r-pods.
LongRanger
Newbie Joined: 13 Jun 2019 Online Status: Offline Posts: 33 |
Posted: 23 Jun 2020 at 7:48pm | |
I wouldn't even know where to begin with replacing counter tops. You all have some mad skills!
New92
Newbie Joined: 16 Apr 2020 Location: Alberta Online Status: Offline Posts: 9 |
Posted: 02 Jul 2020 at 3:49pm | |
The sink in our 192 fell out also. Only 3rd weeend out. Thank goodness it wasn’t full of water (just dishes). Like you I was amazed at the inadequate fasteners just barely hanging onto the sink lip. How much more would have cost if they simply added a washer on each screw! (sorry my disappointment is oozing out (;
I put some construction adhesive along the sink lip then used course thread screws with wide washers. Due to the tight access I used a 6” long drill bit, and it snuggled it up nice. Going to put a bead of clear silicone around the sink edge (192 has under counter sink) Most important thing... I impressed my wife with the repair🤪 We will see how well it holds up. Going on the road for 3 weeks this month...fingers crossed. by the way... love my 192!!
