Slide topper |
Post Reply | Page <123> |
Topic: Slide topper Posted: 20 Jul 2020 at 2:04pm |
Resurrecting an old topic because I need some information. How did you attach the brackets to the slide? It comes with screws and says, "All screws supporting the awning assembly MUST have a backer within the structure of the wall of the unit." Is there adequate backing in the RPod's slide-out? If not, how did you back up the screws so that the brackets did not rip out of the wall?
Posted: 20 Jul 2020 at 3:07pm |
SH,
There is an excellent DIY video available for this awning install, as I recall they supplied RIVNUT type inserts where screws go, but I'd have to watch the video again as I don't recall exactly. |
Posted: 20 Jul 2020 at 3:19pm |
SH, I told you wrong , it uses self tapping screws - you do not want to over tighten, I used Lexel to seal the back and it is also an adhesive. When I put the screws in it was solid behind the slide panel.
Posted: 20 Jul 2020 at 4:08pm |
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ That is what I needed to know. Thank you. Yes, it is self-tapping screws that were supplied. I will take your advice about not overtightening. Did you use clear Lexel?
Posted: 20 Jul 2020 at 5:48pm |
Yes Sir, I used clear. Butyl tape skewed the alignment, I wanted them to set and cure.
Posted: 20 Jul 2020 at 8:15pm |
I got the backing plates installed. They are different now than before. There is a separate backing plate that attaches to the slide-out wall and the mounting plates slide onto that and get locked in place. There are 5 screws for each backing plate. The top three went into what felt like solid wood. The two lower ones didn't. I'm hoping that the three top ones with the Lexel will make up for the lack of solid backing for the lower two. Since it got dark on me, I will let the backing plates cure in place before I put the mounting plates on and install the fabric roll.
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 347 |
Posted: 23 Jul 2020 at 11:45am |
I got a Lippert awing for the slide out and mounting the brackets on the slide out I did just as you have with screws and silicone to secure the brackets and have not had any problems thus far and I installed it over a year ago and used the drainage rail instead of installing the one supplied with the awning and it works slick
Jay
179/2019 |
Posted: 23 Jul 2020 at 12:10pm |
Mine is now complete. There are a couple of minor issues (scratches on the roll ends and two missing self-drilling screws) that I am dealing with. One other thing is that the fabric is not centered on the roll, but is off center by about an inch. It isn't a big difference, but it is something I noticed once I had it installed. I have the fabric centered on the track and slide-out, but the roll is offset just a bit. I'm not sure if it was made that way or shifted in shipment. The assembly functions great and the fabric is tight when it is extended and retracted. I also used the rail that was there instead of mounting the one provided. I'm not sure what I will do with that section of rail. I think I will make small awnings to mount above the windows by the bed so that I can open the windows for ventilation when it rains.
Posted: 23 Jul 2020 at 5:09pm |
Is it white or black, I like mine but regret the white selection.
Posted: 23 Jul 2020 at 6:19pm |
I should have mentioned that I purchased the black one. The white one would have stuck out like a sore thumb. The black one blends in very nicely.
