TVs and antenna |
Post Reply | Page <123 |
paddlewhisp
Newbie Joined: 19 Jul 2020 Location: Atlanta GA Online Status: Offline Posts: 13 |
Topic: TVs and antenna Posted: 23 Jul 2020 at 7:29pm |
Thanks y’all.
Paddlewhisp
Posted: 23 Jul 2020 at 7:34pm |
That ant has 12V that energizes the amp when the amp button is pushed, if the red light comes on, and you have 12V to the amp wire, the amp may not be working. That will be your problem. You will get no reception without amp. The amp is in the ant. Best to just replace, they are not that pricey.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6298 |
Posted: 23 Jul 2020 at 8:21pm |
This is the antenna I purchased after I broke the 2nd batwing antenna: https://smile.amazon.com/gp/product/B010SP0IY4/. I bought it because the base was the same as what was already there so I did not need to remove the base which was still in good shape. Unfortunately, it is not available on Amazon, but may be from other sources. This one looks similar, but the base may need to be changed: https://smile.amazon.com/Magnadyne-RVTV-W2-SEPARATE-F-CONNECTOR-CONNECTIONS/dp/B00USE3JF6/. Both of these come with a new wall plate. You may find that you might need additional wiring if the existing wiring won't quite reach the connections on your stereo unit.
paddlewhisp
Posted: 23 Jul 2020 at 8:29pm |
Thanks for the information
Paddlewhisp
Posted: 24 Jul 2020 at 11:47am |
I used same antenna as SH, only in black.
mjlrpod
Posted: 24 Jul 2020 at 12:10pm |
I have not seen anywhere that the OP has said that they are turning on the antennea booster switch. You MUST have the booster switch on, before seaching for channels. It's a tiny little button on the wall behind the t.v. . You push it in, a red light, lights up. Have you turned on the booster ???? Do you know where it is??
Posted: 24 Jul 2020 at 12:38pm |
True, however numerous posts have mentioned that and at top of this page I told them how to troubleshoot, so at this point I'm assuming they know that.
paddlewhisp
Posted: 24 Jul 2020 at 5:59pm |
We have tried it on and off with the booster .... no luck
We called Forest River service and they are working to figure this out
Paddlewhisp
