  New Posts New Posts RSS Feed: Water Pump; Leave on while camping?
Topic ClosedWater Pump; Leave on while camping?
Poddy View Drop Down
Direct Link To This Post Topic: Water Pump; Leave on while camping?
    Posted: 30 Jul 2020 at 4:53am
Hi guys, as stated in an earlier post, I'm new to RV'ing so i have many "little" questions. About the water pump, are we supposed to leave it on during our campsite stay, knowing there's lots of water in the fresh tank? Or just pop it on when we need water? Or does it matter either way? I own the 2011, 172.
Direct Link To This Post Posted: 30 Jul 2020 at 5:29am
You can leave it on but it will try to maintain pressure so might turn on for a short time in the middle of the night and disturb your sleep, so I suggest you turn it off overnight.  I only turn mine on morning and evening when I'm using water.
Direct Link To This Post Posted: 30 Jul 2020 at 7:21am
+1  Like offgrid we turn ours off at night, once in awhile it may briefly turn on for part of a second and turn off to maintain pressure.  During the day we leave ours on. Ours is also a 2011 model year, have owned it for 9+ years; been a great dependable unit.
mjlrpod View Drop Down
Direct Link To This Post Posted: 30 Jul 2020 at 8:01am
Not that you asked, but just for clarification, you only use the pump to get water from the fresh water tank. You do not need the pump when you have "city water" hooked up to the camper.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Yes, if there is any drip anywhere (such as low point drain or a faucet or a check-valve allowing leakage back through the pump), the pump will run to bring the pressure back up. This may be only a second or less, but it is not something you want to hear in the middle of the night. Turn it off if it disturbs you.
Badweissenbier View Drop Down
Direct Link To This Post Posted: 30 Jul 2020 at 9:15am
No the pump is only used for water from your tank. The city hookup bypasses all that.   Do make sure you have a pressure regulator hooked up in line with the city water or your water pressure could get to high.   The trailers aren’t made for full city pressure.
Direct Link To This Post Posted: 30 Jul 2020 at 10:11am
We only turn on the pump when we are using water, which is primarily doing dishes and/or taking a shower. We leave it off if we aren't using it; especially over night.
Direct Link To This Post Posted: 30 Jul 2020 at 11:29am
Where i live, the option of "city water" is non-existent. Boondock or stay home.
Direct Link To This Post Posted: 30 Jul 2020 at 11:37am
We turn our pump on when we need water, .....unless I forget.  Ermm
Direct Link To This Post Posted: 30 Jul 2020 at 1:31pm
Thanks for clearing that up. For a moment I thought I said only use the pump to get water from the fresh water tank, but you cleared that up, and correctly said that you only use the pump to get water from your tank. I can't believe I was that wrong, Thanks
2020 R-pod 195
I'll be rpodding
