  New Posts New Posts RSS Feed: Water Pump; Leave on while camping?
Topic ClosedWater Pump; Leave on while camping?
Badweissenbier View Drop Down
Direct Link To This Post Topic: Water Pump; Leave on while camping?
    Posted: 30 Jul 2020 at 3:17pm
Originally posted by mjlrpod
Not that you asked, but just for clarification, you only use the pump to get water from the fresh water tank. You do not need the pump when you have "city water" hooked up to the camper.
No the pump is only used for water from your tank. The city hookup bypasses all that.   Do make sure you have a pressure regulator hooked up in line with the city water or your water pressure could get to high.   The trailers aren’t made for full city pressure.
Thanks for clearing that up. For a moment I thought I said only use the pump to get water from the fresh water tank, but you cleared that up, and correctly said that you only use the pump to get water from your tank. I can't believe I was that wrong, Thanks
Ok I'm lmbo, I was on my phone and thought you had asked that as a question. It must be time for new specticals. Probably thought you were the OP.
Direct Link To This Post Posted: 30 Jul 2020 at 4:03pm
Poddy,
I have to ask, where do you live?
Direct Link To This Post Posted: 30 Jul 2020 at 5:17pm
I don't ever use my city water connection either, even in the rare instances when I'm not bookdocking. That way if I run low on water I know its time to dump, I never have more than 250 gallons of water in one tank or another, and I don't need the tank level lights to work.
Direct Link To This Post Posted: 30 Jul 2020 at 5:25pm
I knew you were good, OG, but 250 gallons ?! Confused
So you did figure out how to get that washer/dryer and spa into the pod?
Man, you are good!  LOL
Direct Link To This Post Posted: 30 Jul 2020 at 5:36pm
Poddy didn't say he didn't use it, post said it was non-existent. That is why I asked. I won't comment on 250 Gals. I'm old too.
Direct Link To This Post Posted: 30 Jul 2020 at 5:37pm
Lbs, ha ha! Unless some of it has soaked into the floor Shocked
Direct Link To This Post Posted: 30 Jul 2020 at 9:28pm
Rats, I was hoping to see a pic by OG showing off his new jacuzzi inside the pod and how he did it!
Direct Link To This Post Posted: 31 Jul 2020 at 7:10am
mikeyg2347 View Drop Down
Direct Link To This Post Posted: 31 Jul 2020 at 8:29am
Just make sure you turn the pump off when you're traveling. I accidentally left mine on once and glanced in my passenger side rear view and saw water dripping out the bottom of the door. The kitchen sink faucet handle had vibrated open and I'd put the cutting board over the sink, which caused the water to splash all over the inside of the camper. This was late September in Montana and it took days to dry everything out. I only made that mistake once.
Mike
Poddy View Drop Down
Direct Link To This Post Posted: 31 Jul 2020 at 8:41am
Newfoundland Canada. There are fully serviced sites around but they usually get booked up for the full season by one RV'er
2011 RP172
2015 Toyota Tacoma
Newfoundland, Canada
