Page 12> |
BeagleMom ![]() Newbie ![]() ![]() Joined: 17 Aug 2020 Location: New Mexico Online Status: Offline Posts: 3 |
![]() Posted: 17 Aug 2020 at 3:39pm |
My hot water heater doesn't heat water too well, has trouble firing up and fault light comes on. I've checked fuses, propane and made sure I've run hot water faucet before trying. Does anyone know what causes this? Sometimes it works, sometimes it doesn't. Thank you!
Woody the beagle Mom
What does it do in electric operation?
Besides the above question, we also need to know if the burner is coming on, and staying on for at least 5-10 minutes or so, when in propane mode.
If the water is already hot from the electric element being on, then the burner wont need to be on for very long.
If the water isn't hot at the tap, then check the position of the bypass valves. The ones leading to the top and bottom of the water heater should both be parallel to the lines. The one between should be perpendicular to the line. If the one between is parallel, then hot and cold water are being mixed and the best you will get is warm water.
Ruberu ![]() Newbie ![]() Joined: 20 Nov 2017 Online Status: Offline Posts: 2 |
17 1/2 Rpod 180 Hood River
My Propane line going to the water heater was kinked from the factory. Might be worth a look
180 Hood River
2014 Pilot Nav 4WD |
Its a water heater not a hot water heater. If the water was already hot it wouldn't need to be heated.
Pod_Geek ![]() Senior Member ![]() Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 260 |
Once the really hot water starts to cool off it becomes just hot water and needs to be heated back up...
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
Just an old plumber's joke, not to be taken seriously....
So now I'm in hot water.
Good to laugh! Still trying to solve problem!
Page 12> |
