  New Posts New Posts RSS Feed: Hot water heater 2018 R-Pod 180
Topic ClosedHot water heater 2018 R-Pod 180
BeagleMom View Drop Down
Direct Link To This Post Topic: Hot water heater 2018 R-Pod 180
    Posted: 17 Aug 2020 at 3:39pm
My hot water heater doesn't heat water too well, has trouble firing up and fault light comes on. I've checked fuses, propane and made sure I've run hot water faucet before trying. Does anyone know what causes this? Sometimes it works, sometimes it doesn't. Thank you!
Woody the beagle Mom
Direct Link To This Post Posted: 17 Aug 2020 at 4:26pm
What does it do in electric operation?
podwerkz View Drop Down
Direct Link To This Post Posted: 17 Aug 2020 at 6:05pm
Besides the above question, we also need to know if the burner is coming on, and staying on for at least 5-10 minutes or so, when in propane mode.
If the water is already hot from the electric element being on, then the burner wont need to be on for very long.
Direct Link To This Post Posted: 17 Aug 2020 at 7:24pm
If the water isn't hot at the tap, then check the position of the bypass valves. The ones leading to the top and bottom of the water heater should both be parallel to the lines. The one between should be perpendicular to the line. If the one between is parallel, then hot and cold water are being mixed and the best you will get is warm water.
Ruberu View Drop Down
Direct Link To This Post Posted: 18 Aug 2020 at 8:53pm
17 1/2 Rpod 180 Hood River
My Propane line going to the water heater was kinked from the factory.
Might be worth a look
180 Hood River
2014 Pilot Nav 4WD
Direct Link To This Post Posted: 19 Aug 2020 at 5:51am
Its a water heater not a hot water heater. If the water was already hot it wouldn't need to be heated. Evil Smile
Pod_Geek View Drop Down
Direct Link To This Post Posted: 19 Aug 2020 at 8:05am
Once the really hot water starts to cool off it becomes just hot water and needs to be heated back up...
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Direct Link To This Post Posted: 19 Aug 2020 at 8:19am
Just an old plumber's joke, not to be taken seriously....Embarrassed
Direct Link To This Post Posted: 19 Aug 2020 at 8:24am
So now I'm in hot water.
2018 RAM 2500 6.4L
Direct Link To This Post Posted: 19 Aug 2020 at 8:27am
Good to laugh! Still trying to solve problem!
