Poddy
Topic: Hitching to the TV Posted: 18 Aug 2020 at 8:06am |
I've been using white grease or silicone spray on the ball before hitching to the Pod. Is this a good idea? Or is it over-kill?
2011 RP172
2015 Toyota Tacoma
Newfoundland, Canada
JR
Posted: 18 Aug 2020 at 8:20am |
A little grease goes a long way on the ball, really I think it just helps keep the noise (squeaking) down
Jay
179/2019
EchoGale
Posted: 18 Aug 2020 at 9:09am |
Really? Could you please be more specific about "grease?"
Julie
Posted: 18 Aug 2020 at 9:41am |
Originally posted by EchoGale
Really? Could you please be more specific about "grease?" |
john in idaho
Posted: 18 Aug 2020 at 9:48am |
I think just about any grease would help. Only take a dab. I used some a year or so ago.
Posted: 18 Aug 2020 at 10:33am |
+1. I have a small toothpaste-tube of white lithium grease I keep in the toolbag for this (and other incidentals). Just like Brylcreem, a little dab'll do ya.
mjlrpod
Posted: 18 Aug 2020 at 11:28am |
Grease/lube is a must. I don't know any manufacturer that says " we recommend no grease or lubrication on 2 moving steel parts". Some grease might be better than others, but, any is better than none.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Pod People
Posted: 18 Aug 2020 at 11:35am |
We use a white lithium spray lubricant on the ball before we attach the pod. I wipe it off when we unhook so that it will not accumulate trash or dirt. It keeps both the ball and receiver clean and helps reduce friction and noise. I have seen lots of trailer balls with scars and escratches that came from embedded grit without lube. A lot of people cover their trailer balls with tennis balls when not in use.
Vann
Vann & Laura 2015 RPod 179
podwerkz
Posted: 18 Aug 2020 at 3:08pm |
Did your trailer come with balls?
Posted: 19 Aug 2020 at 5:24am |
Well now, this depends, is it a male or female R-Pod.
