  New Posts New Posts RSS Feed: Trailer hitch block
Topic ClosedTrailer hitch block
bwarren View Drop Down
Direct Link To This Post Topic: Trailer hitch block
    Posted: 02 Sep 2020 at 2:17pm
I have been using red bricks as a landing pad when unhitching Rpod hitch.  Those brick are heavy and I am looking for something lighter in weight to replace the bricks.  Any idea?  Thanks, Bruce
Direct Link To This Post Posted: 02 Sep 2020 at 2:46pm
I use 2, 1 foot long sections of 4x4.
Direct Link To This Post Posted: 02 Sep 2020 at 2:54pm
I just use the same plastic legos I use for leveling the wheels. They weigh nothing and you can adjust the number you use to minimize cranking on the jack.
Direct Link To This Post Posted: 02 Sep 2020 at 3:49pm
or
Of the two, I prefer the Husky although I did have to cut the tube part down and drill a new hole for the foot to fit our driveway Having control over the flip-up foot is somewhat better in my opinion, plus the Husky can go down flat to the tube if needed. The Fastway needs a block to use if there is not enough space to let it flip down. OTOH, the Fastway is (mostly) hands-free. It does need to not be tightened too much and does need a little lubricant so the foot will pivot smoothly and lock into place. The bolt has to be able to slide through the slots to enable it to lock when the trailer front is raised. The Husky's pin locks it in place without having to make sure the foot pivots and locks properly.
Direct Link To This Post Posted: 02 Sep 2020 at 3:50pm
Be careful with red brick.  Some red brick is brittle and has surprisingly low compression strength.  Not all red brick is the same.
Direct Link To This Post Posted: 02 Sep 2020 at 7:08pm
Direct Link To This Post Posted: 02 Sep 2020 at 7:10pm
I use a 12" piece of 6" x 6" spruce/hemlock.  Weighs around 3 lbs.
