  New Posts New Posts RSS Feed: water leak at city connector
Topic Closedwater leak at city connector
Jenga Jack View Drop Down
Direct Link To This Post Topic: water leak at city connector
    Posted: 14 Sep 2020 at 11:11pm
While camping this past week I discovered water leaking inside the R-Pod, against the wall, at the city water connector. I couldn't tell exactly where the leak was coming from: damaged "connector"; clamp where tubing meets connector; hole/split in tubing; etc.
We were hooked up to city water, low water pressure, no leakage visible on outside of R-Pod.
Have any of you experienced this? Any suggestions on how to fix?
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
Direct Link To This Post Posted: 15 Sep 2020 at 8:39am
We had that happen when we did our pre-purchase inspection.  Turned out to be a washer in the hose connection fitting.  Hope yours is that simple.  As I recall, the fitting is attached from the outside so if it is the pex clamp, it's easy to get to.
