  New Posts New Posts RSS Feed: slow drip from insulation around low point drains
Topic Closedslow drip from insulation around low point drains
JR View Drop Down
Direct Link To This Post Topic: slow drip from insulation around low point drains
    Posted: 05 Oct 2020 at 4:00pm
The third valve is for the feed side of the water pump, it either allows flow from the fresh water tank below the flooring or it allows feed from the short hose "that goes nowhere".  You can use the short hose to feed RV Antifreeze (the pink stuff) into the water system for winterizing the water system.  The valve only controls the feed source for the water pump.  Hope this makes sense to you.  Have fun.
Jay
179/2019
