Page <12 |
Rchuter ![]() Newbie ![]() Joined: 30 Sep 2020 Online Status: Offline Posts: 9 |
![]() Posted: 08 Oct 2020 at 9:04am |
Thank you. Converter not charging pretty simple power going in none coming out. Need a converter
Given that it is over 2 years old, check Amazon for a WFCO 8955MBA. Amazon has about the least expensive price. It is not too hard to change out. Just be sure that the shore power is disconnected and the battery is disconnected. When you do replace it, be sure you get the battery polarity correct or it will blow the two 40A reverse polarity protection fuses in the center. Also, do be sure to download and follow the troubleshooting chart. You may find that the problem is not the converter. Why spend money if you don't have to.
Yea have one on the way from Walmart.com fuses an breakers are good not much else it can be. 5 wires yes I watched the marucci video! Lol
Are you sure your battery is good?
Battery good as possible being a killed battery. TV recharged it a lot on way home
Think you got a handle on it. The battery needs a converter, the converter doesn't need a battery. Works best in tandem.
Page <12 |
