waxing my R-Pod |
TEDDY
Groupie Joined: 22 Oct 2017 Location: Arkansas Online Status: Offline Posts: 94 |
Topic: waxing my R-Pod Posted: 05 Nov 2020 at 1:11pm |
Just finsihed washing my R-Pod 178 - used McGuires stuff - good surfactant. The prospect of waxing it, however, is daunting. Does anyone know of a spray on wax/polish (or water-mix wash) that would do the trick? It would be neat if one could apply something and then simply wipe at it with a mitt or cloth, rather then the laborious application of the McGuire's wax/polish. I'm approaching 80 yrs old and some things just get harder!
Also- I have found it hard (using just McGuire's soap) to remove all the small gray spots that are probably mold spots. I have had good results with Spray 'n Forget on wood and concrete - has anyone used it on their R-Pod gel coat?
Teddy
Posted: 05 Nov 2020 at 3:56pm |
Protect-All All-Surface Care is good. UPC: 728652620161
TEDDY
Posted: 05 Nov 2020 at 4:11pm |
Thanks - looks like it comes in spray bottles - might do the trick!
Teddy
Posted: 05 Nov 2020 at 8:52pm |
It also comes in gallon refills. UPC: 728652620109
Pod People
Senior Member Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1078 |
Posted: 05 Nov 2020 at 9:22pm |
we use Meguiares Ultimate Wash and Wax. It is very easy and does not require buffing. after you have washed, simply mix the wax with the recommended water amount and wipe it on with a cloth or mitt. Rinse with water and dry with microfiber. We';ve used it for 6 years and the pod still lokks good. VannIt is vey much a liquid and sheet drains off.
TEDDY
Posted: 05 Nov 2020 at 11:16pm |
Thanks guys. My friend who has a boat has suggested using distilled white vinegar as a wash before using a surfactant (like Meguaires) to actually wash the fiberglass - that would probably take care of the little gray spots.
I think I'll give Meguaire's Wash and Wax a try - on easily with a mitt, then rinse off - sounds about my speed!
Teddy
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 364 |
Posted: 06 Nov 2020 at 7:05am |
StephenH thanks for the sku number of the gallon refill...I have been using the small spray bottles of the Protect All for a couple of years now and really like it.
Jay
179/2019 |
Posted: 12 Nov 2020 at 5:11pm |
Thanks for recommendation.
