Floor Sagging by John Marucci |
Page 12> |
rpod190 ![]() Groupie ![]() ![]() Joined: 07 Apr 2019 Location: Illinois Online Status: Offline Posts: 45 |
![]() ![]() ![]() ![]() Posted: 04 Dec 2020 at 8:33am |
I follow this gentleman and his woes with his Rpod. Having the kitchen in the back puts more stress on the floor whereas my RP190 has only a table and no walking around weight that the models have with a kitchen in the back. Please take a look at John's videos on his rpod and this efforts to get FR to do something. He has alot of good information. Subscribe and get more knowledge & power. Buying An RV During Unprecedented Times - 5 Cautionshttps://www.youtube.com/watch?v=G4JXAApykTc
Wynnster
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1214 |
John is a member here, and posts fairly often. I wouldn't say he has woes with his pod, but he's had a few things happen.
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1068 |
Several of 179 owners have followed his advice and installed floor braces similar to what the factory has done. Vann
I have enjoy his posts and I will continue to follow him. Keep up the good work John!
Wynnster
rawest50 ![]() Senior Member ![]() ![]() Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Anybody know about how much throat fix is costing? My are sagging.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. ![]() |
Throat fixes are expensive. Ask your otolaryngologist for a quote before agreeing.
The fix involves finding someone to fabricate a brace for you. The materials are not too expensive. The expensive part is geting it cut and welded to the right dimensions. with plates drilled so the brace can be installed. It has to be the width between the frame which may vary by a little, so measure carefully so it will go in and not leave any big gaps between the plate and frame. If you want it powder coated, that will be extra. Mine came unpainted, so I had to wire brush it and then paint it. Some prices will vary depending on whether you can do the welding yourself or whether you need to find a metal shop to do the work. Total should still come to under $100. You can use the same type #14 self-drilling/tapping screws used by FR in the rest of the braces to install it.
2017.5 RPod 179
SPrins ![]() Newbie ![]() ![]() Joined: 22 Jan 2021 Location: TN Online Status: Offline Posts: 2 |
I will be doing a variation of this repair later in the spring. Will document with photos as we move along. I plan on making a grid of sorts using 1.5 inch square tubing and a sheet of 1 inch PVC sheeting. This way I do not have to worry about wrapping the sheeting to prevent water damage.
I will also be bracing the floor that extends over the frame below the slide out. I will be using 3 pieces of 1/4" thick angle iron 3 x 5 inches that is 12 inches long. Will also post pics of that project as well. I do not believe I have either of these issues occurring with my 2018 - 179; but am taking a very proactive approach to make these items non issues. |
2018 R-Pod 179
2020 Ford F-150 3.5L Ecoboost |
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
If I were to do it over, I would likely go with the aluminum brace displayed in this video:
Page 12> |
