DC outlets |
Post Reply | Page <123> |
Topic: DC outlets Posted: 15 Jun 2021 at 1:39pm |
The fuse will protect the wire. I don't recollect the gauge but it runs two 12v fans and my dual voltage TV fine. Don't use it to run an inverter or something like that.
Pod People
Senior Member Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1078 |
Post Options Quote Reply Posted: 15 Jun 2021 at 9:37pm |
That's what I did--dedicated fused circuit from the panel, under the bath and terminated under the bed adjacent to the wardrobe wall. This is now a junction box that serves all of the new 12v devices that I added in the " bedroom" area.Makes for easy access to add more as needed. Vann
wthoms2000
Groupie Joined: 06 May 2017 Location: Costa Mesa, CA Online Status: Offline Posts: 44 |
Post Options Quote Reply Posted: 01 Jul 2021 at 12:13am |
Ran a cig lighter outlet behind the TV. Ran another on the kitchen cabinet next to the front door above the fire extinguisher. This line I ran from a spare fuse holder on the inverter to under the door jam.
And incredible there were no 12V outlets or USB ports! So I also added next to the door a dual USB outlet with voltage readout. Enjoy! |
Porta Poddy
Wil and Luz, Orange County, CA 2017.5 179 HRE 2021 Ranger XLT FX4 REDARC Brake Controller |
poston
podders Helping podders - pHp Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 197 |
Post Options Quote Reply Posted: 01 Jul 2021 at 6:37am |
It is incredible. Maybe it's a indication that Forest River thinks in the "full hookup" world, where you plug in your AC adapter to get USB power. I also installed a "power center" with 12V outlet, 12V gauge and USB-C and USB-A ports. We love it! |
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2595 |
Post Options Quote Reply Posted: 01 Jul 2021 at 8:20am |
I don't know why someone doesn't come up with a better 12v plug system than the clunky cigarette lighter style. For dry camping, more 12 plugs would be handy, but the big cigaret lighter tube plugs take a lot of space inside the wall, limiting where they can be installed and the male part of the plug is vulnerable to getting hit and damaged. The SAE style plugs used for the newer solar connections, or something like it, would work much better.
poston
Post Options Quote Reply Posted: 01 Jul 2021 at 8:55am |
Anderson Powerpoles are a good way to deliver power. Very solid. The Powerpole distribution box is compact. |
TheBum
Post Options Quote Reply Posted: 01 Jul 2021 at 10:45am |
USB-C ports with Power Delivery could replace the accessory socket because they support a lot more amperage than plain USB. USB-C PD can deliver 100W laptop power and can deliver a variety of voltages, so it should work for most 12V devices.
Alan
poston
Post Options Quote Reply Posted: 01 Jul 2021 at 11:26am |
I put a USB-C PD 48W socket in one of my slots, but I don't appear to be getting that much power. I think it's my external cable though. I bought a USB-C tester to measure power delivery but haven't sussed it out yet.
Post Options Quote Reply Posted: 02 Jul 2021 at 7:25am |
The problem really isn't the receptacle/outlet. You could use any rated receptacle for a 12v circuit. The problem is the plug, the danger being that if you wire up your 12v appliance with a plug that is normally used at 120vac you could later inadvertently connect it to a 120vac circuit and find out where the smoke was hidden.
Hence the cig lighter convention. The cig lighter outlets are typically rated for 15a which will provide around 180 watts. There are surface mount MC4 connectors available if you can find them but that is really overkill anyway for 12vdc as they are rated for 600vdc (non load break). You can readily get SAE surface mount connectors (like the "solar port" on rpods). I'd suggest using that if you don't like the cig lighter standard. Just cut off the cig lighter plugs and replace them. Check the current rating of the connectors you get (you see numbers between 15 and 30a) and if the manufacturer doesn't list one then try to get something else. The wiring also has to be able to handle the current (14awg for 15a, 12awg for 20a, 10awg for 30a). Also be sure that you wire the appliances you connect for the same polarity you have wired the wall receptacles as the SAE standard doesn't specify that. And use the applicable fuses back at the distribution panel... |
Post Options Quote Reply Posted: 02 Jul 2021 at 8:57am |
I like PowerPoles and use them with my HAM equipment. However, since my CPAP machine and other items I have use the cigarette style plugs, that is what I have in my RPod.
