Weight distribution/anti sway - Event Date: 23 Jul 2017 |
Page <1234> |
![]() ![]() ![]() ![]() Posted: 25 Jul 2017 at 11:21am |
Higher weight rated WDHs are harder on the tow vehicle structure because they don't absorb as much force. This is especially important if you're using something like the Highlander, which is unibody. Ideally, you should get the next size above your actual tongue weight.
@rawest50: The low numbers are the tongue weight values. Typically, WDHs are rated by tongue/pull weight (e.g. 600/6000 for the E2 I use). I suspect your 10000 pound rated WDH is 1000/10000. |
rawest50 ![]() Senior Member ![]() ![]() Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
You are correct. I was at the dealer today and looked at their e2 display. Saw the 1,000 tongue weight and 10,000 tow weight. I will say it tows behind my Jeep like it is not there when on level or downhill road. I assume the load/sway is doing a fantastic job. |
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. ![]() |
Johncmarshjr ![]() Newbie ![]() ![]() Joined: 24 May 2017 Location: Maine Online Status: Offline Posts: 21 |
Thank you for the advice
Has anyone used the EAZ-LIFT 48056 ELITE? It is rated at 600 lb and has a 2 5/8 ball that will need to be changed out.
ALICE
Is a four way significantly better than a two way for a 179 Rpod? I am pulling with a Volvo rated at 5,000lbs.
ALICE
We used almost that exact setup at first and the biggest drawback is that you have to remove the sway bar before backing up. My wife didn't once and the ball on the A-frame anchoring one end of the sway bar ripped right out. The E2 doesn't have that restriction and my wife finds it easier to set up. |
In fair weather, I doubt you could tell the difference. If you have moderate to high crosswinds, the 4-way will do a better job of fighting sway than the 2-way, but the 2-way still does a pretty good job. |
wdwrkr ![]() Newbie ![]() ![]() Joined: 04 Feb 2022 Location: Michigan Online Status: Offline Posts: 4 |
I have a 2019 R-Pod 180 and pulling it with a 2018 Highlander. I've been looking at Blue Ox (BLU36FR) Weight Distribution w/Sway Control. Is this compatible with the R-Pod 180?
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2632 |
That would be pretty close. The BLU36FR is rated for a tongue weight of 600 lbs. For an RP180, I might be inclined to go up to a BLU47FR, which is rated for 800 lbs. It's usually better to go up a little than to be too low on the weight rating.
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
I’ve used the Blue Ox Sway Pro for five years on my 179 and love it. I’ve had the 550lb bars and it’s worked fine. The adjustability on the fly is a big benefit - if you go out with a full freshwater tank and add tongue weight, it’s easy to notch up the tension and move weight off the tongue fore and aft.
Winterpod ![]() Newbie ![]() Joined: 17 Oct 2015 Location: Ketchum Online Status: Offline Posts: 35 |
I tow a R-Pod 178 using the e2 400-4500 WDH WITH SWAY CONTROL.
Winter pod
2013 R-Pod 178 2007 Silverato 1500 LT. Trek Stash 8 29er hard tail Old Town Kayak |
Page <1234> |
