Weight distribution/anti sway - Event Date: 23 Jul 2017 |
Page <1234> |
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1214 |
![]() ![]() ![]() ![]() Posted: 26 Feb 2022 at 11:25am |
I would recommend the 600 pound spring bar set up. Going more than that the bars are to rigid, and will actually begin to cause damage. You always want to be as close to the actual tongue weight as possible. I've been told this is not a "bigger is better" situation. Otherwise I'm pretty sure they would only sell the 1000 pound set up.
Winterpod ![]() Newbie ![]() Joined: 17 Oct 2015 Location: Ketchum Online Status: Offline Posts: 35 |
Tongue weight 330, spring bars 400 seems to work fine the last five years.
Winter pod
2013 R-Pod 178 2007 Silverato 1500 LT. Trek Stash 8 29er hard tail Old Town Kayak |
There is no reason to expect damage from stiffer wdh bars. Regardless of what bars you have you will be setting up the wdh to bring the weight on the front axle back to where it was before the trailer was attached. On my Highlander with the 179 at 500 lbs tongue weight that was a tension of about 750 lbs. You would have the same tension on a lighter wdh to achieve the same result. That's just the way the math works out.
So the problem with too low a rating is that the bars might fail in bending when hitting a swale if they don't have enough reserve capacity beyond what is needed to load the front axle. The problem with heavier bars is that the ride might get stiffer than you prefer. I ran 1000 lb bars on my rig and the ride was fine. |
Rpod-Couple ![]() Newbie ![]() Joined: 21 Jun 2021 Online Status: Offline Posts: 37 |
I did a search for WDH failures and all I could find is wear at the spring bar sockets or a blue ox spring bar weld failure. And these are on trailers weighing over 7000 lbs with 1000 lb spring bars. I couldn’t find any where the spring bar failed. We all read about R-pod axles and frames being bent. Sizing the spring bars to the hitch weight (or next size up) seems best. I started with 1000 lb spring bars and switched to 600 lb and it smoothed out my ride. The 1000 lbs bars made for a jarring ride.
Anyone able to point to a 400-600 lb spring bar failure on a 400-600 lb tongue weight application?
Steve & Elaine
2021 R-pod 2023 VW Atlas Cross Sport |
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
Isn't that a uni-body SUV? If it is, you may not be able to buy a hitch that can accommodate a weight distributing hitch. With your self-adjusting air suspension, you likely don't need it, either. I use and recommend a friction sway damper as suspenders. But, if you get your tongue weight %-age right, you won't need that either.
John
'16 R-Pod 180 |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3237 |
I took the wise advice from some on this forum and found 11% or more of the total trailer weight on the tongue works great under all sorts of weather/wind conditions. Having a 177 for 11 years now we have only used the anti-sway bar and it has worked well.
An air suspension is not at all the equivalent of a wdh.
All an adjustable suspension does is bring the ride height of the tow vehicle rear axle up. It does nothing to place weight back on the front axle, which goes down, not up, when you attach a trailer. Having sufficient weight on the front axle is critical to safety and h proper handling since the front axle does the steering and had the best brakes. So by all means get a wdh if you have a relatively light yuw vehicle for the trailer youre hauling around. Of course, regardless of whether you have a unibody or body on frame vehicle, do not exceed your tow vehicle, trailer, and combined vehicle specs, and don't use a wdh if the vehicle manufacturer disallows it. |
I think the question was directed at my 2010 Mazda CX-9? Yes it is a unibody, but there is a beefy boxed sub-frame around the rear axle that the hitch attaches to. The vehicle has the same chassis, suspension and drive train as the Ford Flex. Interesting that Ford rates the flex at 4500 lbs with a class 3 hitch, brake controller and transmission cooler which I have. The CX9 tow rating is 3500 lbs in the US but the identical model in the rest of the world is 4500lbs. I think Ford forced Mazda to derate the CX9 in the US to help out sales of the Flex. Probably more info than you wanted to know. I can’t help it - I am an engineer. 😉
My tongue weight with WDH included is right at 425 lbs. |
Steve & Elaine
In Europe and elsewhere there are different standards for rating tow capacity. So theoretically identical vehicles can have different ratings in different jurisdictions.
This is very common in all kinds of products. As an engineer responsible for global product certifications I saw this all the time. There are many reasons for this, some purely a matter of how the standards evolved, some based on real differences in usage. We for example travel longer distances at higher speeds, have higher mountains, and have more extreme weather than in most other countries. In many countries there is also specific training required for towing. Regardless, we and the product manufacturers that sell here have to abide by our standards, so what a similar vehicle is rated for or what the theoretically identical vehicle is rated for elsewhere is not material. It is illegal to overload your tow vehicle, and that includes not only trailer and tongue weight but also gross combined vehicle weight and axle weights. If you get stopped or are involved in a crash and are found to be exceeding your 3500 lb tow rating you will be the one cited. Don't do it. |
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 290 |
I see a lot of unibody vehicles pulling trailers. Just yesterday I saw a Highlander pulling a small Airstream Bambi down I25 near Las Cruces. I've always heard a frame on body tow vehicle is best but it seems unibody vehicles do just as well. A friend pulls a Retro with her Highlander with no issues.
I use a Fastway E2 600lb WDH on the Frontier. I've pulled in blazing sun, wind, rain, snow, hail (sometimes all in the same day) with no issues for the past 5 years. Gino 2017 Rpod 179 2016 Nissan Frontier SV
Page <1234> |
