  New Posts New Posts RSS Feed: door fits too tight
door fits too tight
wdwrkr View Drop Down
Post Options Post Options   Quote wdwrkr Quote  Post ReplyReply Direct Link To This Post Topic: door fits too tight
    Posted: 27 Jul 2022 at 1:29pm
Our r-pod fits too tight. any suggestions to help correct this?
Post Options Post Options   Quote wdwrkr Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 1:30pm
oops, r-pod door fits too tight
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 2:33pm
Hello wdwrkr,
What year and model? That information might help. Also, define what you mean. Is it binding on one of the corners, along one of the long edges, or somewhere else? One of the causes of finding seems to be by being too aggressive in raising the stabilizers which can warp the frame temporarily and lead to binding. Screws loosening might also be a cause.
Post Options Post Options   Quote wdwrkr Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 8:10pm
We have a 2019 r-pod 180. It's the door latch that is binding.  The two parts, on the door and on the frame, scrape against each other making it difficult to open and close the door.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 9:03pm
I would try using a flat file (lightly) to take some of the excess plastic off so the fit is better.  First though check all screws on the door to make sure they are all tight.  Also is there an adjustment you can make on the latch?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 10:39pm
+1 on Jato's advice.
LB Boozer View Drop Down
Post Options Post Options   Quote LB Boozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 6:47pm
Great advice from Jato.
Is your fiction hinge really tight,  I was getting binding on my door and tried all kinds of solutions.  The thing that finally fixed it was lubing the hinge.  Since it has worked perfectly.
