Rpod single tank regulator |
Barryb125
Newbie Joined: 06 Jul 2018 Online Status: Offline Posts: 24 |
Topic: Rpod single tank regulator Posted: 08 Aug 2022 at 12:55pm |
Hello All;
Another question for the group. I don't have my 2017 Rpod 178 manual but I need a new propane tank regulator. Can anyone advise me the model number or other specifics so I can order a replacment? Thanks Barry
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2589 |
Post Options Quote Reply Posted: 08 Aug 2022 at 2:12pm |
Propane tank regulators for RV's and gas grills are pretty fungible. You can buy pretty much any one you want for that general purpose. They are not trailer model or brand specific. Your local RV parts shop or on line sellers have lots of them that will work fine.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3237 |
Post Options Quote Reply Posted: 08 Aug 2022 at 3:24pm |
The standard single stage regulator made by Camco is item# 17-59013. Cost (2020 price) $ 25. If you plan on running a few appliances together then (fridge, HW heater, stove, furnace and outdoor cook stove) you may opt for the two stage model. I have owned a 177 for over 11 years and have had fridge, inside burners, HW heating up, and furnace all on at the same time and have never had an issue with the single stage regulator.
Barryb125
Post Options Quote Reply Posted: 08 Aug 2022 at 3:31pm |
Thanks all, replaced the regulator, now I have a leak and can't figure out why.
poohbill
Groupie Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Post Options Quote Reply Posted: 08 Aug 2022 at 3:52pm |
My pigtail developed a leak. You might replace it, if you haven't already. Also, doping the connections is always recommended.
2016 179 Gastropod
2017 Ridgeline |
Barryb125
Post Options Quote Reply Posted: 08 Aug 2022 at 4:09pm |
I have replaced it and wrapped it with gas tape, how tight do those connections fit? Doesn't seem to want to recess completely, I still see some threads, is that normal?
Thanks Barry
mjlrpod
Post Options Quote Reply Posted: 08 Aug 2022 at 4:45pm |
Yes, it's normal. You will see a few threads after it's tightened. You used the yellow tape on the threads before screwing in the threads, right?
Barryb125
Post Options Quote Reply Posted: 08 Aug 2022 at 5:41pm |
I redid the tape and that fixed the leak. Thanks for your help.
