Trouble with door, sagging wall |
Page <12 |
janr-181g ![]() Newbie ![]() Joined: 05 Sep 2019 Location: Minnesota Online Status: Offline Posts: 1 |
![]() ![]() ![]() ![]() Posted: 19 Sep 2022 at 1:28pm |
This is an old thread, and I did not realize I was a member here.
I have the sagging wall issue with a 2013 181G. In the process of repairing, I noticed a gap in the lower trim, and found I had water infiltration in the wall by the slide out. I also noticed the fiberglass buckled at the lower edge. Since I had the lower piece of trim removed, and had access to inside the wall, I found that the wall frame, which sits on top of the floor platform, had shifted laterally outward 1/4". The wall is connected to the outer floor frame, by screws driven from below. In removing these screws, I found the ones by the shifted wall are broken off at the point where they meet. I have no pressed the wall back in to alignment and fixed the delamination in the outer wall. The wall is no flat, the buckle at the bottom removed. I would say that one side of my trailer was held together by gravity and caulking. |
Better than string and chewing gum I guess....
Page <12 |
