Electrical Wiring Diagrams ??? |
Page 12> |
rPodCamping ![]() Newbie ![]() Joined: 28 Mar 2020 Location: Michigan Online Status: Offline Posts: 21 |
![]() ![]() ![]() ![]() Posted: 18 Oct 2022 at 1:08pm |
Hello Fellow rPoders..............
![]() Has anyone attempted to acquire an electrical wiring diagram for their trailer from Forest River.....or anyone else? I realize each trailer will likely be wired a little bit differently, i.e., wire location and placement may vary. But it seems to me that every rPod MODEL should have a basic electrical wiring diagram that shows the basic AC and DC layout based on the options that come with that particular model. Am I just dreaming? Bob Grand Rapids, MI |
JR ![]() Senior Member ![]() Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 349 |
I have never heard of anyone having a wiring diagram, the closest you can get is to ask some specific questions on this forum and maybe someone has already been there and done that. Be sure to include your rpod model number and year of manufacturing. Just keep in mind that your trailer has 2 separate wiring systems which you have pointed out the 12 volt side and 110 volt side. The trailer's battery(ies) feed the 12 volt side of the breaker box and the shore power plugin feeds the 110 volt side of the breaker box. Everything going through the breaker box is either fused or has a breaker and then it is distributed out into the trailer. The fuse and/or breaker labeling is the only indication of the trailer's wiring. There are exceptions to this and what comes to mind is the trailer's wiring for the running lights and breaking system and possible an electric awning. Hope this helps. And if you are dreaming I hope they're not bad dreams.
Jay
179/2019 |
lostagain ![]() Senior Member ![]() ![]() Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2588 |
One would think FR would want to follow a consistent wiring system for both AC and DC with pre-made harnesses and such as are used in cars, but they seem to prefer to have the wiring in each trailer a bit different with each build. At times, I wonder if FR hired Lucas Electric (the Prince of Darkness)to design their 12 vdc systems.
RoverPod ![]() Senior Member ![]() ![]() Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Wiring diagrams don't exist for them. The wiring installation can change from day to day.
2017 F150 XLT SuperCab
2020 rPod 180 |
See...............that makes no sense to me.
How can FR ensure quality and consistency in its product line without wiring diagrams that the installers must follow?
I am very familiar with AC & DC systems in my trailer, and how the power center functions and distributes electricity throughout the trailer. That's not my question.
An electrical wiring diagram would be helpful to me personally in diagnosing issues, making modifications, identification of circuits through wire color-coding, etc etc etc. I just heard from FR today. They will not provide them and you can't get them through the dealer network either. Too much liability..................
The problem with having detailed documentation of your product, like a wiring diagram, is that then you would actually have to build them that way.
![]() Consider this. If FR provided you with a wiring diagram for your trailer, it would be reasonable for you to rely on it being accurate. If it wasn't and as a result you burned up your trailer with you in it, the litigation would seriously hurt FRs bottom line, or worse. THAT is what FR really means when they say there is too much liability. Would it help FRs product quality if they could build their trailers consistently? Of course. But it's not in their manufacturing culture to be able to do that. And it's very difficult and expensive to make that kind of change. You lose lots of staff who resent all the controls. Believe me I've been there. I'm not just singling out FR BTW, the whole RV industry is like that other than a few high end brands. So, you won't see what you're asking for. Just generate your own schematic, and only trust it as far as you have personally verified the wiring. IOW, don't assume something is wired up the way you think would be logical.... |
+1 to OG.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3229 |
+2 to OG On our recent 30 day trip last month we actually camped at a park with electricity behind Pikes Peak (Mueller State Park). Long story short, even though I was plugged in, nothing worked on 120, went back to battery, same thing. Kind of thought this trip was going to be cut short, I was out of ideas, and our slide was out as well. Fortunately my mechanical engineer brother helped to troubleshoot, and even then the electrical wiring made no sense, color wise on some of the switches, especially the toggle for the slide. Fortunately when we ordered this 177, back in January 2011 it was ordered without A/C, microwave/convection oven, or entertainment system (we rarely go where there is electricity anyway). He suggested I take the red wire off the converter (coming from the 120 feed) and put it on one of the open lugs that would have been used for A/C or the convection oven. I did and everything worked! Believe me, I was very thankful! Apparently the circuit must have shorted out on that line. So if this happens again (hopefully not) there is still 1 more open circuit to attach to.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
You can pretty much figure that all wiring emanates from the power panel. Figure the shortest distance between that point and the thing you are providing power to. 12V up to the lights and probably the entertainment system and antenna amplifier. 120VAC to each of the things that require it. There will also be 12VDC coming to the power panel from the trailer connector. Not a lot more than that other than the emergency brake (and brakes & running lights) from the trailer connector.
Page 12> |
