GFI outlet |
rawest50
Senior Member Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Topic: GFI outlet Posted: 23 Oct 2022 at 6:41pm |
My GFI will not reset. Is there another way to check it to see if it is the GFI or another problem?
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. |
Senior Member Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1447 |
Post Options Quote Reply Posted: 23 Oct 2022 at 9:23pm |
Unplug everything is one way. If it still won't reset it's easy enough to replace. They do go bad. TT
FJ Cruiser |
Post Options Quote Reply Posted: 24 Oct 2022 at 4:30am |
+1 If everything is disconnected and it won't reset then either it's bad (most likely) or you have a wiring fault. Easiest way to determine which is to disconnect from power and replace the GFCI receptacle. If it still wont stay on then it's the wiring, probably moisture in one of the GFCI protected receptacles. If you don't have easy access to a replacement GFCI receptacle for test purposes you could remove it and temporarily connect the downstream load receptacles to the line conductors coming in using wirenuts. Be sure to keep track of which pair of conductors are the line side and which the downstream load side., GFCI receptacles have line and load cinnection points.
rawest50
Post Options Quote Reply Posted: 26 Oct 2022 at 3:53pm |
Thanks. I have only 1 gfi that the other 3 outlets are on. All other 120v is working. I have had issues before with resetting but this time it will not. Buttons are hard to push.
2017.5 RPod 179
Colt
Post Options Quote Reply Posted: 30 Oct 2022 at 6:06pm |
It won't reset unless it has 120V, either.
John
'16 R-Pod 180 |
