mystery switch |
J.G.S. ![]() Newbie ![]() ![]() Joined: 14 Dec 2022 Location: Bastrop Texas Online Status: Offline Posts: 3 |
![]() ![]() ![]() ![]() Posted: 19 Dec 2022 at 2:13pm |
J.G.S.
Winterpod ![]() Newbie ![]() Joined: 17 Oct 2015 Location: Ketchum Online Status: Offline Posts: 35 |
I would think it is the switch for the outside light
I could be wrong it’s known to happen
Winter pod
2013 R-Pod 178 2007 Silverato 1500 LT. Trek Stash 8 29er hard tail Old Town Kayak |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3237 |
It is for the outside light. If light fails to turn on then you will have to replace the bulb. Easy fix, take a flat screwdriver and carefully insert at the bottom of the fixture, slight twist and lens will pop off. |
Agreed. It is the outside light switch. It would be a good opportunity to replace a non-working bulb with an LED bulb.
poohbill ![]() Groupie ![]() Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Odd. The switch on our 2016 179 for the outside light is black, with an oversized, unlabeled, cover plate. The HVAC controller is on the left side of the toilet door, with the switch for the toilet light.
2016 179 Gastropod
2017 Ridgeline |
That falls under the rule, "Let no to 'Pods be built the same." Mine is similar to the picture with some variation on relative height of the switches. Only the bathroom light switch is to the left of the door.
The outside light works with the switch that's on the light. The switch for the bathroom light is to the left of the door. I have 48 years in aircraft maintenance and repair. I believe I know how to change a light bulb. I am coming to understand that these campers are built one at a time and are wired differently.
Thanks all for the replies .
J.G.S.
