Sway Bars Needed? |
Post Reply | Page <1234> |
Topic: Sway Bars Needed? Posted: 30 Sep 2021 at 9:32pm |
+1 big time.
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2588 |
Post Options Quote Reply Posted: 01 Oct 2021 at 8:00am |
+1 to Pod People. Not only is a WDH safer, it also makes driving more comfortable and the ride smoother, especially when you have to cover a long distance.
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
Post Options Quote Reply Posted: 01 Oct 2021 at 1:39pm |
I have the Hayes Sway-Master as well and it works great. It activated this week on our trip in a spot where the was a large dip to the right in the road and it put the brakes on immediately as the trailer swayed with the dip. I have noticed it working a few times when the winds were high. My Escape has electronic sway control not sure that it helps any.
pedwards2932
Post Options Quote Reply Posted: 01 Oct 2021 at 2:09pm |
Found this on the Escape's Sway control:
When properly equipped, trailer sway control will use the sensors of the vehicle’s AdvanceTrac with RSC system to detect and attempt to mitigate trailer sway by applying brake force at individual wheels and, if necessary, by reducing engine power. No driver action is required. I got the Hayes unit because it activates the TT brakes.
Thomasandrews628
Newbie Joined: 27 Jan 2024 Location: FL Online Status: Offline Posts: 3 |
Post Options Quote Reply Posted: 06 May 2024 at 9:02am |
My name is Tom and I recently bought a 2015 Rpod 176 camper,then I purchased a 2018 GMC Canyon SLE 3.6 8 speed,do I need a distribution/sway hitch for my combination?I don't travel very fast pulling anything anyway.Thanks for advise.
TA
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Post Options Quote Reply Posted: 06 May 2024 at 9:49am |
It's never a bad idea to use a WDH. It transfers part of the tongue weight back to the front wheels. The degree to which it helps is driven by the weight ratio between the tow vehicle and the trailer.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 288 |
Post Options Quote Reply Posted: 06 May 2024 at 11:49am |
I would highly recommend it. We towed a 179 with a short bed Nissan Frontier crew cab as well as a long bed Frontier crew cab. A WHD with built in sway such as a Fastway E2 offers both weight distribution and anti sway. Even towing slow, you will run into road and environmental conditions that will induce sway.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Online Posts: 3230 |
Post Options Quote Reply Posted: 06 May 2024 at 7:17pm |
I ride on the other side of the fence on this issue when looking at the original, smaller rpods. With the larger ones, especially the 2x axle yes, great idea and likely safer as well. In our case we have traveled with our 177 (fully loaded with 36 gallons H20- FW tank behind axle, weighs in at 2940 lbs.) for the past 13 years and over 44,000 miles, much of that going across the Midwest to get to the Rockies, and yes we have encountered huge cross winds in the process. Our tow vehicles for the first 8 years were an '08 and '13 front wheel drive Explorer, the last 5 have been with a '95, '11, and '17 F-150. All vehicles utilized a simple Curt friction bar and nothing else, no bad experiences or issues encountered and this is over all sorts of weather conditions such as blizzards, sleet, hail, heavy snow and rain, and cross winds in excess of 25 mph. We keep the tongue weight just north of 11% at 340 lbs. which imho, makes a huge difference. A lot of problems have been encountered by those using WDH on the small trailers, the major one being the separation of front and side panels noted on the front of the trailer. I have not seen this as an issue for those who only use a friction bar, though I am sure there have been some due to leakage issues.
EchoGale
Post Options Quote Reply Posted: 10 May 2024 at 9:17am |
Quick caveat though...weight distribution is not recommended with some tow vehicles. My BMW x3 is, I have learned, a unibody and I can use only sway control. Thankfully, when I spent a bunch of money on a WDH/sway control system before I knew this, I bought the Andersen. When I did learn about the unibody restriction, I called Andersen. They told me I could still use my equipment because of the different way it accomplishes weight distribution and that, if I tightened the chains down a little less, I am effectively only using the sway control.
I already had the equipment and it was a couple of years old at that point so I don't have reason to not believe them....
Julie
gpokluda
Post Options Quote Reply Posted: 10 May 2024 at 10:57am |
This is probably true for any WDH. You would just adjust to lessen the tension on the spring bars. That being said, you have added a bunch of weight that you would not need if you went with a simple ball hitch and friction sway bar. I know our E2 hitch alone was pretty heavy. Add the spring bars and hardware and my guess is there was easily 60-70lbs in the WDH alone.
Gpokluda
