  New Posts New Posts RSS Feed: Tow Vehicle Effiency
CUGrad90 View Drop Down
Post Options Post Options   Quote CUGrad90 Quote  Post ReplyReply Direct Link To This Post Topic: Tow Vehicle Effiency
    Posted: 30 Jun 2024 at 8:38pm
I'm wondering what kind of MPG some of you are getting behind your tow vehicle?
I tow my 171 with a 2011 Honda Pilot. It gets the job done just fine, but a recent mostly flat run from NC to FL showed 10.6 MPG for the nearly 1000 mile trip. And that's on the liar meter on the dash, not my calculation at the pump.
Whose getting better fuel efficiency, and with what tow vehicle?
Been thinking about upgrading, either my pickup to one of the Ford ecoboosts, or my wife's Pilot for a SUV with better MPG, if there is such a thing.
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 7:36am
we tow our Vista Cruiser 23 foot with our Ford F-150 with the V-8 engine. Depending on the wind, we average 13.5 on our trips up and down the east coast. We had tail winds this last trip in the spring we averaged 14.5 down and 14.7 coming home.
we use exxon/mobile mid level gas. we average 60 mph. I use both the little trip computer in the truck and double check it
the mileage and gallons used.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 1:13pm
We get 14 MPG towing with the 3.5L EcoBoost for the most part (depending). If we're doing hills, it will be a little worse than that. If we have favorable terrain/wind conditions, it can be a little more than that.
I use the lie-o-meter (which I have corrected through Forscan), and also have an app on the phone that tracks it on a per-tank basis. After correcting the lie-o-meter, it matches very close to actual.
When we're not towing, we get between 18 and 22. 18 when around town doing starts and stops. 22 when we are cruising on the freeway with favorable conditions.
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 2:19pm
When we lived in NV we routinely got around 14 mpg towing our trailer with our F-150 2.7 ecoboost.  Now that we live in the east, all of our mileage is worse, and we get closer about 12.5 to 13 mpg towing.  I wonder if the gasoline formula differs and if there is more ethanol in the gas here.  We've lost about 4 mpg for regular driving compared to what we got out west.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 8:42pm
We tow a small, fiberglass fifth wheel (tandem axle, 5500lb GVW) with a Ford 3.5 Ecoboost with 10speed tranny. We're having a bad day if we get bellow 12mpg. Usually closer to 14mpg in varied terrain and weather. The mileage you get with your Pilot is about what we would get when we pulled our 179 with a Nissan Frontier 4.0L. I know it doesn't make sense, but when an engine can spend more time in the lower RPM range, it's going to get better mileage.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 10:08am
We have towed our 179 for 7 years with both a 2012 Ford Expedition v8 and our new to us 2022 F150 3.5L Ecoboost. We have always used regular gas with 87(?) octane and have not tried higher rated fuel.
 The Expedition V8 usually gave us about 9-10 mpg depending on travel conditions. We recently came back from a 3 week round trip from NC to Texas. Towing with the F150 Ecoboost was much easier and we averaged 14.2mpg over 2500 miles. When not towing, we just averaged 21.9mpg on a weekend trip to the NC mountains
 We find the F150 to be extremely comfortable, easy driving/riding  and a great tow vehicle.  We added an ARE camper shell and Bilstein shocks on the rear. Everything else is standard Ford 10 speed
 I hope to keep this F150 as our tow vehicle for the rest of our trailering days
 Travel often and safe
Vann
Vann & Laura 2015 RPod 179
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 1:38pm
Same 177 has been used for 13 years, loaded weight is 2940 lbs. and that includes the 36 gallons of water located behind the axle.  Tongue weight is 340 and a Curt friction bar is utilized.  First 8 years - .'08 and '13 front wheel drive Explorer's - average was 12 mpg. Next two years '11 F-150 with the 5.0 V-8 Coyote engine - 11 mpg.  Last 3 years '17 F-150 3.5 V6 with ecoboost - 13 mpg.  In all cases 87 octane (a couple exceptions we went with premium but only saw a 1 mpg or so increase, not worth the added cost, also all above include a lot of driving in the Rockies) was used, our destination from northern Michigan.  Speed is normally 60 - 65 mph.
Post Options Post Options   Quote CUGrad90 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 9:25pm
Just a follow up, however many months later...
Just made pretty much the same trip from NC to Fl and back...and this time got 12.6 on the Pilot.
I definitely took it much easier on the accelerator. Maybe that's the reason.
I also had 2 kayaks strapped on a kayak rack top of the pilot. I'm not aeronautical engineer, but I'm wondering if that might have actually helped break up the air in front of the camper and contributed to the improvement.
I'm heading back down to Jacksonville in a few weeks without the kayaks, so I'm going to see if that changes things.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2024 at 10:38am
I wouldn't think that a couple of kayaks on top of the tow vehicle would help. Some kind of air tunnel tests would be needed to confirm. Most of the drag from a trailer is actually the vacuum bubble behind that big box.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2024 at 9:11pm
Just returned from a 30 day, 6000+ mile trip towing a loaded 177 (2940#) from MI to IL to IN to IO to NE to CO to UT to AZ and then returned home going thru CO to NE to SD to MN to WI and back to Michigan.  Used 87 octane (never more than 10% ethanol) and averaged 13.2 using the trailer towing mode.  Gas prices ranged from 2.79 in Iowa to 4.49 in Colorado and 4.19 in Arizona.
