  New Posts New Posts RSS Feed: Tow Vehicle Effiency
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Topic: Tow Vehicle Effiency
    Posted: 03 Oct 2024 at 9:25am
Originally posted by jato
Just returned from a 30 day, 6000+ mile trip towing a loaded 177 (2940#) from MI to IL to IN to IO to NE to CO to UT to AZ and then returned home going thru CO to NE to SD to MN to WI and back to Michigan.  Used 87 octane (never more than 10% ethanol) and averaged 13.2 using the trailer towing mode.  Gas prices ranged from 2.79 in Iowa to 4.49 in Colorado and 4.19 in Arizona.
We have an F150 with the 3.5 Ecoboost motor and 10 speed tranny and we are in the same ball park as you are with regards to mileage. Truly a wonderful motor and transmission combo. Towing with that combo is stressless for both the driver and the truck.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
scroc View Drop Down
Post Options Post Options   Quote scroc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2024 at 6:59pm
We just finished a trip from western Idaho back to the southern Oregon coast, R-Pod, 2024 RP194 came across the scale at 3550 lbs and tugger, 2013 Nissan Frontier at 5400 lbs. Averaged 13.2 for trip using true gallons and miles, several 5k+ passes and some bad winds between Burns and Lakeview.
The Nissan does a good job, maintains 48-55 on the uphills at 2700-3200, could spin it and go faster but were retired so wandering easy is fine with us.
Steve, Cheryl, & critters.
2024 R-Pod 194C
2013 Nissan Frontier 4X4
1 small pup, 1 big cat travel buds
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 7:40am
That's really good mpg WOW. But I think your secret trick is driving below 55 mph. Enjoy your travels.
Jay
179/2019
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 8:36am
Burns and Lakeview.
Wow. You must be living right to get that kind of performance out of the Frontier. We never got close to that and we travel lighter than some backpackers! Good for you!
Gpokluda
2022 Escape 5.0TA
Kawasaki KLR650
Post Options Post Options   Quote scroc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 10:35am
We run the OBD link app with their MX BT hooked into the scan port on the Frontier. This gives us real time info on whats happening with the Tugger so you can adjust driving habits accordingly.
We started with this tool in 2016 on our old Trek and found it was a great help with maintaining and monitoring the power train systems so we have continued updating and using it on all our tow rigs since then.
With the electronic throttle controls on most rigs today small incremental movements of your foot make a considerable difference in amount of fuel being used to cover the distance.
Enjoy our new Pod, Steve & Cheryl
2024 R-Pod 194C
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 8:55pm
I admire your dedication to data. I usually just put gas in the tank and point the thing in the direction I want to go and press on the accelerator. You all take it to a whole new level.
Gpokluda
2022 Escape 5.0TA
Kawasaki KLR650
