Topic: Heater power Posted: 07 Aug 2011 at 6:24pm |
Question...
Does anyone know if the power wires to the heater motor have 12v all the time? I am guessing so, but thought I would ask.. We are going to add a couple 12v receptacles, 1 I will add in the front street side dinette bench, right next to the 120v outlet, and put it on a stand alone circuit from the fuse box, 2 circuit positions are available. Rather than pulling a wire to the back of the trailer, I thought to tap into the power line for the heater fan.. if it's energized full time.
Just wondering if someone knows or has done such a thing.. We use the living daylights out of her iPhone and speakers for music.. and of course we want to be able to take advantage of that dual battery mod we did this week..
TerryM
Posted: 07 Aug 2011 at 7:17pm |
The furnace does run on 12v. Even if you don't have hookups. So, yes there is 12v all the time.
Terry
Chuck
Posted: 12 Aug 2011 at 8:08am |
furpod (or anyone else that can comment), You mentioned the "dual battery mod" that you did. Did you include a switch between them? I have 2 batteries and it's a pain to disconnect and reconnect each time I want to switch. I sure would like to put in a switch but know nothing about what to use or the challenges of that kind of install.
Z-pod
Chuck Janet & Bogie the dog
'12 RP 177
1972 Shasta 1400
2005 Ford F-150 5.3L V8
Posted: 12 Aug 2011 at 9:25am |
Nope, no switch. I do intend to add a disconnect switch to turn them off completely. They are wired together.. as far as the system knows, it is just one large battery..
My theory on batteries says that I want them to charge and discharge together. My batteries are both from the same lot number, came off the same pallet at my dealers..
If you are going to put some kind of switch between them, like a dual propane set up has, then you would have to keep them isolated, and switch back and forth for charging also.. some thing I see no need for. I know back in the day, isolating the coach battery from the house battery was a big deal the manufacturers hadn't thought of.. other than that, I can't really see what the benefit of "selectability" is in a TT..
Chuck
Posted: 12 Aug 2011 at 9:53am |
How do you wire them together? Is there any trick/risk to doing it?
Z-pod
'12 RP 177
1972 Shasta 1400
Guests
Posted: 12 Aug 2011 at 10:53am |
I'll throw in my $.02
Here is my disconnect switch
There are several suppliers of switches. You only need one. In addition, you'll need 2 short battery cables, which can be purchased at Walmart, AutoZone, etc.
If you would like a picture of my dual set up - I'll take one for you.
Chuck
Posted: 12 Aug 2011 at 2:06pm |
If you would like a picture of my dual set up - I'll take one for you. |
I'd love a pic if it's not too much trouble. Thanks
Z-pod
'12 RP 177
1972 Shasta 1400
Posted: 14 Aug 2011 at 5:05pm |
Originally posted by Chuck
I'd love a pic if it's not too much trouble. Thanks |
Hopefully, someone will show you the right way.
Posted: 15 Aug 2011 at 4:48pm |
furpod, take a look at David's first link, above. They way you have yours wired, over time you will stress the battery that is directly attached to the 'pod's battery terminals. Its an easy solution, just move the positive battery cable from the battery on the right (in your middle picture) to the battery on the left.
Posted: 16 Aug 2011 at 3:43pm |
In what way do you believe it to be stressed?
