mt868
Topic: Gate for TT Storage Posted: 10 Nov 2011 at 12:32pm |
I have a 24' opening in the yard. I want to build 2 - 12' gates that swing open so I can store my TT and boat back there.
Does anyone have any suggestions on how I should build this? I hear it needs to be either steel or Chain Link (with vinyl slats for privacy). Wood will sag or break.
Any suggestions would be great since I have no idea how to proceed with this project.
Guests
Posted: 10 Nov 2011 at 1:06pm |
Thanks one whopper of an opening! I'll have to scratch my noggin a while.
Will the gates be over gravel, pavement or grass?
mt868
Posted: 10 Nov 2011 at 1:37pm |
Gates will be over dirt right now. May put gravel on top later. It was grass but I just had a guy level the area so it could grow back to grass later.
Posted: 10 Nov 2011 at 2:25pm |
You might still be ok with wood as long as you add two turnbuckles (with threaded rod) in an X pattern on the back to give each door rigidity. That's how large barn doors are done.
dsmiths
Posted: 10 Nov 2011 at 2:49pm |
You Might check on stock gates that are premade. If you are near a farming community, we have Orchelins, Rural King and several AG minded stores, they are welded primed metal gates, you could probaly set 6 by 6 in concrete and bolt gates to poles, they are generally steel tubing, but I am sure you could fabricate slats or some light weight material for privacy. good luck.
Dane and Donna Smith
2011 RP-172
lift kit
Posted: 10 Nov 2011 at 6:26pm |
Tractor Supply used to be in Texas. They would have stock gates.
2011 R-Pod 177
2010 Ford F-150
marwayne
Posted: 11 Nov 2011 at 11:36pm |
I dont think it matters much if you use wood or chainlink,(chainlink no upkeep) but I think you should put a spring loaded wheel on the bottom of each gate to keep it from dragging.
thechemist
Posted: 03 Dec 2011 at 8:53am |
go to tractor supply, they have very sturdy gates for sale. My driveway has 2 12' gates on 6x6 posts, been there for 3 years and no sag.
Posted: 05 Dec 2011 at 2:09pm |
Welcome, thechemist!
