Brigs
Topic: hooking up the dvd player Posted: 10 Jul 2012 at 9:25am |
good day all
So my wife and i just picked up the 176T, we loved the fact that it came with a tv and dvd player to keep our 3year old busy, and to give him something to watch before bed. So the tv comes with the RCA cables but there is no where to hook the cables into the dvd player because it is mounted into the entertainment stand. can somebody help me out, because the army didnt teach me how to carefully dismantle something, just removal by force, and i would prefer not to take that route this time.
thanks
Keith
Posted: 10 Jul 2012 at 9:56am |
I don'tknow what you have for TV/DVD. In my 177 it is a one piece unit, and no external connections are necessary. You choose input source from the remote control and it takes care of things by itself. If you have something different your mileage may vary. Welcome to Pods! Edit: I just took the virtual tour of your pod and see that the TV/DVD is nothing like mine. Please wait for a good answer from one of the other podders here who really knows!
2011 R-Pod 177
2010 Ford F-150
Posted: 10 Jul 2012 at 10:54am |
Welcome. Sorry that I can't help either, mine is a one-piece unit, too.
Brigs
Posted: 10 Jul 2012 at 11:57am |
im assuming that the DVD player has hook up's on the back but i cant figure out how to get it out, which means that i will also have to drill some holes to run the cables to the TV
Posted: 10 Jul 2012 at 12:03pm |
Are you sure that the player isn't hooked up when you get it, and you change inputs on the tv to get it to work?
2011 R-Pod 177
2010 Ford F-150
Footslogger03
Posted: 10 Jul 2012 at 12:06pm |
Originally posted by Brigs
im assuming that the DVD player has hook up's on the back but i cant figure out how to get it out, which means that i will also have to drill some holes to run the cables to the TV |
I've got a one-piece unit too so can't help there. But if I understand this last post correctly, it sounds like you want to hook the OUTPUT of the built-in DVD player into a separate TV ? Is that correct ?. Not sure if that is possible with the unit that comes with the Pods.
That being said ...I do have a 22" flat panel TV hooked up in our 177. I split the incoming cable signal to the rear of the entertainment center box and fed separate leads to the built-in TV/DVD/FM unit AND to my 22" flat panel. That way if I am at a campground that offers cable TV I can mount the 22" TV and watch is from the dinnette area instead of squinting at the little 9" drop-down on the built-in unit.
Make sense ??
'Slogger
Livin' the Dream ...'Slogger
Brigs
i tried switching through all the sources, eg tv, av1 av2 hdmi, etc and nothing. only time it worked was when i pulled my son's portable dvd player out of the truck and hooked it up to the tv
Brigs
Posted: 10 Jul 2012 at 12:12pm |
Mine came with a 19" tv but i cant get the dvd player out to get video from the dvd player to the tv
Brigs
Posted: 10 Jul 2012 at 12:56pm |
this is what the seperate dvd system looks like
The E Train
Posted: 10 Jul 2012 at 1:19pm |
I have the 176T.... It was not intuitive, but here is how it works.
The main thing to know is that the sound comes through the wall speakers (not the TV)
The yellow RCA cable plugs into the back of the TV (video 1, yellow) from the single wall RCA outlet.
The red and white RCA cables are not used.
Then select source of Video 1 on the TV.
Let me know if that is not clear.
2002 Dakota (pulling a) 2012 R-Pod 176T
