rex
Topic: FRESH WATER TANK HITS GROUND Posted: 06 Oct 2012 at 7:12pm |
THIS AFTERNOON my BOYS AND MYSELF WENT TO A BACK WOODS CAMPING AREA TO WATCH SOME FOOTBALL/EATS SOME RIBS/DRINK SOME BEER IN ALL HAVE A GOOD SAT IN THE WOODS.THERE IS A PLACE WHERE YOU CAN GET WATER FROM A UNDER GROUND SPRING/WE HOOKED UP HAD A FEW COLD ONES NOT PAYING ATTENTION TO THE WATER WHEN WE HEARD A LOUD THUD/WALKED AROUND THE POD A SAW THE WATER TANK ON THE GROUND TWICE THE SIZE IT SHOULD HAVE BEEN.AFTER CHECKING IT OUT WE FOUND THE OVER FLOW TUBE PLUGGED UP.LOOKS LIKE A MUDDOPPER WAS AT WORK.DRAINED TE TANK IT WENT BACK TO ORIG SIZE.IN THE MORNING WE WILL TRY TO GET BACK IN PLACE.AND HOOK ALL BACK UP.SOMETHING TO THINK ABOUT .HAPPY TRAILS TO ALL rex pHp stuart fla
jrr
Seanl
Posted: 06 Oct 2012 at 11:26pm |
Wow I did not think it was posible to over fill like that.
TerryM
Posted: 07 Oct 2012 at 6:52am |
It must have broken the straps that hold up the tank too. That IS something to keep in mind. Thanks for posting this.
Terry
rex
Posted: 07 Oct 2012 at 7:39pm |
TERRY,HAD NO STRAPS,ONLY A PC OF ANGLE FRONT AND REAR TO HOLD IT IN PLACE,WE GOT BACK IN PLACE TODAY .MY BOY IS GOING TO RIG SOMETHING UP TO HOLD IT SO THIS WONT HAPPEN AGAIN.WE DIDNT THINK WE COULD OVER FILL IT ALSO,HAD A LOT OF WATER UNDER THE SINK WHEN IT DID FALL THROUGH.AND PULLED THE DRAIN TUBE OFF.
jrr
TIDALWAVE
Posted: 08 Oct 2012 at 9:10am |
I wondered about my Pod's tank after filling it full and noticed that it bulged downward quite a bit toward the ground. If the tank is held only in place by angle clamps fore and aft and pulled out because of overfilling...I wonder what would happen if you were traveling with a full tank and hit a really large bump. The g-forces should be enough to pull the tank 'tabs' out from the clamps and drop it on the road way. I am going to go out to my Pod and see if there is any way to check on the tightness of the clamps. "Loose clamps-potential fallen tank!"
TIDALWAVE
Posted: 08 Oct 2012 at 10:59am |
Maybe going to add a strap of some sort...
Posted: 08 Oct 2012 at 11:49am |
On my Pod the fresh water tank is filled from a filler that I cant screw a hose on to. I was told by the dealer to put the end of the hose right into the filler and run the water until it started to come out. Are some pods equipped differently?
2011 R-Pod 177
2010 Ford F-150
TIDALWAVE
Posted: 08 Oct 2012 at 6:45pm |
Keith-N-Dar...my Pod's tank fill neck is the same. I bought a tank filling nozzle from Wal-Mart. It has a standard hose valve connected to a 9 inch clear poly tube. You insert the poly tube into the open fitting and give the valve a quarter-turn. If the tank fills completely water rushes out from around the poly tube. I believe this design is so that you can't over-pressurize the water tank.
TIDALWAVE
Podsible Dream
Posted: 08 Oct 2012 at 7:54pm |
Ditto on our 171.
Chris and Walt
'10 RP-171 'Free Spirit'
Posted: 08 Oct 2012 at 8:58pm |
Yup, that's how all campers have been since I started in '86.
