More winterizing |
Post Reply | Page <12 |
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Topic: More winterizing Posted: 22 Oct 2012 at 8:25pm |
Robwid, how cold do the temps get there ?
Dane and Donna Smith
Posted: 22 Oct 2012 at 9:30pm |
Robwid, the intake hose and valve must be plumbed in right before the water pump intake, so moving it would require one of several options. It could be done but it would mean adding a lot of extensions to the existing hoses. I would only do the blow-out method in a mild climate where hard freezes are rare - basically Florida. There is too much opportunity for water to remain in the valves and low points. Take the extra 15 minutes and gallon or two of antifreeze for peace of mind, IMO. |
Robwid
Groupie Joined: 31 Oct 2011 Location: Oregon Online Status: Offline Posts: 67 |
Posted: 22 Oct 2012 at 10:26pm |
dsmiths,
Hard freezes are quite rare on the "valley floor" as we call the Portland area. We are only about 100 feet above sea level here. That said, if we get a sustained east wind it can get into the 20's. Next weekend I'm going to see if I can wrangle the mattress out of the way enough to pull the plywood off and look for the antifreeze line. Thanks all for the comments! |
Rob
2012 HRE 177 2010 Toyota Tacoma |
Camper Bob
podders Helping podders - pHp Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Posted: 22 Oct 2012 at 10:47pm |
We are at 512' according to City Hall, here in Lake O. I have been sweating out whether to fully winterize or not. Did look and did not find the free hose end to add anti-freeze. Soo, have ordered the Camco kit to add the valve before the water pump under the sink in the kitchen. Would be a whole lot easier and cheaper to just blow out the water, however thinking about a freeze and having to replace plumbing lines I have decided to go the whole nine yards. Temporarily have lit the ceramic heater this evening where currently it is hovering about 44 degrees. When the kit comes in and after our last trip of the year on Nov. 8 will blow out the lines, empty all tanks, install the Camco valve and empty the water heater. Then will add antifreeze to all lines and wash and cover the Rpod for the winter. That's my plan. As far as wrestling the mattress, I had installed two pneumatic lifts which make lifting the bed a breeze, and had a large hinge installed on the far side of the bed. Works like a dream even with the 50 lb. mattress. Safe Travels.
Camper Bob and Camper Sue
dsmiths
Posted: 22 Oct 2012 at 10:55pm |
50 lb mattress ??? good grief.
Camper Bob
Posted: 22 Oct 2012 at 11:39pm |
Ahhh. But you have to remember that after a full day of sitting in my camping chair, sipping wine, taking a nap, taking a very short hike to the store for "goodies" a man needs a comfortable mattress to sleep on after a very weary day. Actually it's one of those European style pillow top mattresses sold by Camping World. It is extremely comfortable. I can't think of much worse while camping, than being cold at night and not being able to sleep. This really fits the bill. About $329. but worth every dime. It truly is a giggle to lay down on it. Anyway, couldn't sleep on the one from FR. Safe Travels.
RPodWeGo
Senior Member Joined: 10 Jul 2012 Location: Salt Lake City Online Status: Offline Posts: 112 |
Posted: 23 Oct 2012 at 12:53am |
Greetings, I winterized my 2012 177 this past weekend. If you search "bypass" you will find a few comments on this topic. The 2012 177 does not have a bypass valve and "built in" suction hose. If you look under the bed you will see a "cross beam" piece of wood with the water ump screwed to it. When you look at the pump, the right side has a metal looking screen. This side is the intake side. Slide that blue locking thing up and wiggle out the hose. Put a hose into the hole making it as snug as possible, other end into a jug of antifreeze, turn on pump and watch pink come out of your faucets.
Caution though, follow all steps of the winterization process in this forum prior to do this and importantly turn those 3 valve handles you see the opposite direction than they are PRIOR TO pumping the anti freeze.
RPodWeGo
RPod 177 04 v8 Toyota 4Runner |
Robwid
Posted: 23 Oct 2012 at 10:09am |
Camper Bob,
Who installed the pneumatic lifts? That sounds like a great idea! |
Rob
