  New Posts New Posts RSS Feed: Winterization
Topic ClosedWinterization
 Post Reply Post Reply Page  <1 891011>
RPodWeGo View Drop Down
Direct Link To This Post Topic: Winterization
    Posted: 02 Nov 2012 at 4:33pm
Does anyone know the size of the anode rod bolt? I saw it somewhere on this forum and I have now searched for a few days without success. Thanks. Happy Weekend.
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
mountain mist View Drop Down
Direct Link To This Post Posted: 02 Nov 2012 at 5:30pm
mine is a inch and a 16th... just took it out to drain hot water heater...
'11 Forest River r.pod 171
'10 Ford Edge
ESCAPE POD
Trudi and Austin mini-schnauzers
change here, Trudi has gone, Austin now has a small black schnauzer buddy, Bentley
this_is_nascar View Drop Down
Direct Link To This Post Posted: 06 Nov 2012 at 9:06am
Thanks, we did.
"Ray & Connie"
- 2017 R-Pod RP-180
Alaskaflyer View Drop Down
Direct Link To This Post Posted: 09 Oct 2016 at 5:16pm
Don't forget to winterize the outdoor shower!
ccamp126 View Drop Down
Direct Link To This Post Posted: 25 Oct 2016 at 8:09am
Good list of steps for winterization. My first time. One question: after draining water heater and trying to flush out some rod residue, I noticed there is a small amount of water that will not drain out as plug hole is about 1/2" above bottom of tank. What is the best way to get that water out? Or is it OK for it to freeze?
ccamp
Direct Link To This Post Posted: 25 Oct 2016 at 9:05am
With that small an amount of water, expansion while freezing should not be an issue. If the tank were full, then expansion would potentially burst the tank. It is like an ice cube tray. It works because the water can expand upward while it freezes. Likewise with the tank.
For the anode rod, look for Suburban part number 232767, which is the Suburban Magnesium Anode Rod. The magnesium is good for most purposes. With excessively corrosive water where the magnesium rod is consumed too quickly, the aluminum one can be used. Suburban's instructions on the package say that if the magnesium one lasts less than a year, use the aluminum one (part number 232768).
pgoelz View Drop Down
I just winterized our 2014 171 for the first time (bought it used this spring) and I have a couple questions..... my only other winterization experience has been blowing out the very simple system in our old pop up.  That was one line.  The Rpod is more complex.
1.  I see reference here to low point drains..... I did not realize my 171 had them (and they are not in the manual).  I blew the system out thoroughly with compressed air and then filled it with RV antifreeze (pink from all taps and toilet).... can I assume opening the low point drains (if present) is not required?
2.  I drained the fresh water tank (and the water heater is dry and bypassed with the anode out) but I forgot to run the pump to suck any water out of the intake hose before I sucked in the antifreeze.  Since the intake for the antifreeze is (I assume) in the fresh water intake line between the tank and the pump, can I assume that any remaining water in the line between the bypass valve and the tank itself has either drained out or is not an issue if it freezes?
I found the owner's manual to be VERY generic and it left lots of questions.  However, it does instruct winterization by pouring antifreeze in the fresh water tank, which I guess would take care of my concerns above?  I decided not to put antifreeze in the tank since I don't know how long the tank would have to be flushed in the spring to get rid of any remaining antifreeze.... and taste.
Thanks,
Paul
Direct Link To This Post Posted: 25 Oct 2016 at 9:17am
I did put antifreeze in my fresh water tank last year. I did a couple of flushes along with sanitizing with chlorine and then a flush with baking soda. I did not notice any residual taste when I got done. However, I have since made a hatch for easier access to the winterization valve/hose and will not repeat the antifreeze in the fresh water tank. I will drain the tank and then run the pump until all water is purged from the intake line. Then I will change it over and pump antifreeze through the pipes. It should simplify the sanitizing and flushing in the spring.
However, we do have one winter trip planned. I won't use antifreeze in the fresh water pipes until after that trip. I'll use air to blow out the lines since we will add water as we get to the southern portion of our trip.
Direct Link To This Post Posted: 25 Oct 2016 at 2:13pm
Thanks SH. I was thinking the same, but wanted to be sure. Any reason to put the anode rod back in?
ccamp
Direct Link To This Post Posted: 25 Oct 2016 at 8:47pm
I don't know. I'd have to do some research on that.
