Burt
Topic: Non-Ethanol Gas Posted: 11 Apr 2013 at 3:02pm |
I have been asked about Non-Ethanol gas many times and found out that it does have more power per gallon than the corn fuel we are forced to buy.
Therefore, when you tow with a vehicle at or near capacity, Non-Ethanol will pull you around easier and even get better mileage.
Here is a website that will help you locate REAL GAS:
www.pure-gas.org
If you use a smart phone, it will give you directions, coordinates, addresses, etc....
Happy Towing
Burt
Racer|X|
Posted: 11 Apr 2013 at 7:56pm |
Ethanol sucks!!!! My Ford will get 22-23 MPG with real gas....down to 16-17 with ethanol (not towing).
Bad part is, living in farm country it is hard to find. Much more common and available in the "Up North" as we say in WI or the Northwoods.
X
Posted: 11 Apr 2013 at 9:21pm |
Fleet Farm gas stations normally have ethanol free gas. Check it out if you have one near,
2011 R-Pod 177
2010 Ford F-150
Racer|X|
Posted: 11 Apr 2013 at 10:41pm |
Farm and Fleet by me. Those two always crack me up. Greatest store on the planet though...I can spend hours in one. When the Zombie Apocolypse comes, I want to be near a FF, everything you need for survival. 😄
Posted: 12 Apr 2013 at 5:15am |
We are positioned so we can easily get to both, but we are in Fleet Farm country. I like em both too. Does Farm and Fleet have gas stations?
2011 R-Pod 177
2010 Ford F-150
coopercdrkey
Posted: 12 Apr 2013 at 10:32am |
I guess that is another advantage to living near the water- outboard motors do not do well at all on ethanol-laced gas. Even the convenience store here on the Key has a non-ethanol pump. Costs more, but at least it's available.
Bob and Joyce
RP 177 "Key Pod"
Burt
Posted: 12 Apr 2013 at 10:41am |
You noticed it big time...marine! Sta-Bil does also make a marine formula which is meant for reducing or eliminating ethanol in gas.
It's a blue color not like the brown/yellow color.
I carry some of that when towing in case I can't find real gas.
Burt
TIDALWAVE
Posted: 12 Apr 2013 at 11:09am |
About a quarter of the gas stations here in Central Mn carry hi-octane (90) ethanol-free gasoline. It is used for "non-automobile" uses such as high-compression autos, ATVs, outboards, lawn equipment, etc. It generally costs about 10% more than 10-15% ethanol gas. So do an experiment...let your tow vehicle get low on fuel and fill up totally with the non-ethanol gas and record your odometer setting. Record the mileage when you are again nearly empty and refill with standard ethanol gas. Repeat and check your mpg...if you get a higher mpg percentage using non-ethanol than the higher percentage gas price, it is more economical to fill with the non-ethanol gas.
TIDALWAVE
Racer|X|
Posted: 12 Apr 2013 at 9:56pm |
Our gas stations will have the high octane non-ethanol for "recreation vehicles" as the signs usually state.
Keith...Farm & Fleet doesn't have gas pumps by me.
X
Posted: 13 Apr 2013 at 7:50am |
I hd never seen one with them but I have not seen them all. Thanks,
2011 R-Pod 177
2010 Ford F-150
