  New Posts New Posts RSS Feed: Slide out
Topic ClosedSlide out
Newbie View Drop Down
Direct Link To This Post Topic: Slide out
    Posted: 24 Jun 2013 at 7:18pm
We have the rp177 , is there any way to manually put slide in if for some reason you were to lose power.
Rp177
2013 grand caravan
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 24 Jun 2013 at 9:24pm
If you remove the panel on the inside of the pod at the bottom of the slide I am told there is a nut you can put the wrench for the stabilizer jacks on to run the slide in or out without poer. I have never tried it.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 24 Jun 2013 at 9:45pm
Yes. Just as Keith-n-Dar said. Right hand bottom panel. The nut is the same size as your stabilizer jack handle...
Never done it on a/the Pod.. but HAVE cranked a slide in once. A skill I don't intend to perfect.
the smart thing to do if you lose power is hook up your tow vehicle..
Direct Link To This Post Posted: 24 Jun 2013 at 9:49pm
Thank you
Rp177
2013 grand caravan
Seanl View Drop Down
Direct Link To This Post Posted: 25 Jun 2013 at 8:45am
I would suggest an 18 volt drill or impact wrench with a 3/4 inch socket on it to run the slide in if it stops working for any reason. I use one to run my stabilizer jacks up and down. Yes I am lazy and getting old.Tongue
hogone View Drop Down
Direct Link To This Post Posted: 25 Jun 2013 at 8:48am
One note: Hooking up to the TV will only help if you have the charging system from the TV  activated and/or available
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 25 Jun 2013 at 9:28am
Ya I got tht activated so would work TyTy
Rp177
2013 grand caravan
Direct Link To This Post Posted: 25 Jun 2013 at 9:38am
jumper cables man, jumper cables. No truck should be without a set. You can move way more power through them in a short time than through the "charging cable" of the TV.
Smile
Direct Link To This Post Posted: 25 Jun 2013 at 10:01am
Oh, jumper cables.  Sure, that would work too!!!  Your right, that would be much more efficient.  Thanks for setting me straight!!!!  I will be honest, I do not have a pair in my truck.  Thet will be in there tonight however.
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 25 Jun 2013 at 8:48pm
jumper cables, a pair of pliers, quality 12 volt air pump, and a tire plug repair kit.
