Battery added? |
Julia1961
Newbie Joined: 23 Aug 2013 Location: Florida Online Status: Offline Posts: 29 |
Topic: Battery added? Posted: 26 Nov 2013 at 4:56pm |
I am in the process of having a second battery added at the dealership with a cutover switch, has anyone had any experience having an additional battery added? If so, how did you do it if done as a modification, and how much weight did it add. I am a new plodder, I bought an RPod 171 2010. Any feedback will be appreciated. :)
The Vintage Glamper
Lilly Pod |
Posted: 26 Nov 2013 at 6:04pm |
Welcome. It will add roughly 75 pounds. If your existing battery isn't brand new you will want to go with two new batteries, otherwise the old battery will kill the new battery fairly quickly. It is best if you go with two 6 volt batteries (wired in series), but if you must go with two 12 volt batteries in parallel make sure you connect the (+) to the camper to one battery, and the (-) to the camper to the other battery. Always charge them and use them together, NOT one then the other. You actually get more total amps out of the batteries that way due to something called the Peukert Effect. With any camper you must make sure to use your cutoff switch to disconnect the batteries after a trip otherwise "phantom loads" in the camper will kill the batteries in about 2 weeks (maybe 4 weeks with 2 batteries). Once per month reconnect the batteries and plug the camper in overnight to top them off, then disconnect the batteries again. Also top them off overnight before a trip while also pre-cooling your fridge. |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3252 |
Posted: 01 Dec 2013 at 5:00pm |
We have now used our (2) 12 volt batteries for 3 years w/o any problems. No fancy cutoff switch; when the one gets down to 1/3 of a charge, I use my 1/2" wrench and switch the cables to the other battery; it takes less than 2 minutes to do this.
Normally we drycamp and do the bulk of our camping during the off season here in the North country (April - May) and (September-October). The furnace usually gets a good workout, our last 2 big trips were at Glacier N.P. and Rocky Mountain N.P. both in September where the night temps would drop into the mid to upper 30's. We easily get 3 days out of 1 battery, 4 if the night temps stay in the 40's. Interior lights are all L.E.D.'s and fridge is kept on propane. |
