  New Posts New Posts RSS Feed: Help on sway control and hitch
Topic ClosedHelp on sway control and hitch
Seanl View Drop Down
Direct Link To This Post Topic: Help on sway control and hitch
    Posted: 29 Nov 2013 at 11:36pm
Originally posted by HavaPod
...also, what does WDH mean?...
Weight distribution hitch. A hitch that transfers some of the weight off of the rear of the TV and into the front wheels of the TV and the trailer axle.
hogone View Drop Down
Direct Link To This Post Posted: 30 Nov 2013 at 8:12am
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 30 Nov 2013 at 8:19am
trying to research before i ask, but i guess i'm not finding what i'm looking for.  so it appears a sway/friction bar attaches to the camper with bolts/screws and to the tv on the shank on a small ball.  do i need to get a new shank for this or is there an adapter?  jloftin 60, you posted a picture of one that seems of interest to me.  where is that from?  i didn't see it on etrailer.  appreciate any info.  also, do these need to be disconnected when backing, making sharp turns whether going forward or backing?  hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 30 Nov 2013 at 8:38am
This is the E2 Trunion Weight Distribution Hitch from Fastway. It combines  friction sway control with Weight Distribution. You in no way have to go this route. Many here just go with a bolt on friction sway control.  I went this route because my wife found the bouncing up and down the the TV did when we hit a bump uncomfortable.  The two bars are spring bars that resist the rear of the TV sagging and bouncing. They also transfer some weight of the weight off of the tounge to the front wheels of the TV and the axle of the trailer.
Direct Link To This Post Posted: 30 Nov 2013 at 9:44am
ok, still researching.  now i see what outbound means in regards to the weld on bracket!!!  just green in this area!!!   i see they sell shanks with the bracket on, but haven't seen one with a 4 inch drop, but i guess a good welder could do it right.   ok, now another question.  if your only using one bar, does it matter on which side  you put it on?  etrailer and the hitch store have a curt bar for $46.  any thoughts.  thanks for everyone's input, hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 01 Dec 2013 at 9:40am
just purchased the bracket and bar from etrailer............$84.95
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Sleepless View Drop Down
Direct Link To This Post Posted: 01 Dec 2013 at 11:00am
You had mentioned a bracket that had to be welded on to the tongue.  Mine is attached with 6 self-tapping screws which only require large pilot holes.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 01 Dec 2013 at 11:16am
sleepless:  I was talking about a bracket that gets welded to the receiver hitch for the ball for the sway bar to attach to.  ya, the bracket that attaches to the pod is screwed in.  I found a bracket that just fits under the ball however, like the picture jloftin60 posted.  i think outbound used the bracket that gets welded onto the receiver hitch.  hope that all makes sense.  do you find that a sway bar helps alot?
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 01 Dec 2013 at 4:41pm
We purchased our 177 nearly 3 years ago and brought it home in March during a snowstorm; no problem with sway, even though we had a fair amount of wind traveling across the U.P. of Michigan.
The first 'shakedown trip" was another experience however.  Once we got above 45 MPH we got a massive amount of sway with about a 10-15mph crosswind.  We opted to spend the big bucks, about $ 85.00 and got a sway bar for our Explorer; problem solved, never had an issue since that was installed.  Maybe for some of you big boys with the longer wheelbase this is not necessary, but for those of us with smaller TV's and shorter wheelbases, this is a must in my opinion.
Direct Link To This Post Posted: 01 Dec 2013 at 5:01pm
Either side of the tongue is fine for a friction sway bar.  You DO need to remove the friction bar from one ball or the other while backing.  You do not need to do anything while backing with a WDH.
