flat tire |
Post Reply | Page <123 |
Senior Member Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1447 |
Topic: flat tire Posted: 26 Feb 2014 at 8:50pm |
We have had very different experiences with flats. It's been a while for me too, but I don't think I can recall ever have the bead separate from the wheel. It's interesting that your experience is so different. As for plugs, they generally work well, but I'm pretty sure they void tire warranties. TT |
FJ Cruiser |
Posted: 26 Feb 2014 at 9:01pm |
Never had a bead problem except on my small tractor tires.
Posted: 26 Feb 2014 at 9:47pm |
Ah, now that you mention that -- I knew I had some sort of experience with broken beads. Yes, with a riding lawnmower, a wheelbarrow, or a two-wheeler hand truck I have dealt with broken beads. Little tires with practically no air in them to begin with and hardly any sidewall strength can definitely have bead problems. 14 inch trailer tires are more likely to have problems than larger TV tires too. TT |
FJ Cruiser |
Sleepless
Senior Member Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Posted: 26 Feb 2014 at 9:59pm |
As I mentioned, my problem with beads goes back several years. Back in the late 70's and the 80's I was into restoring the older British sports cars. Almost every time I had a flat, the tire bead separated from the wheel. I had the same experience whenever I had a flat on one of my popup trailers. These were all 10" wheels. I don't recall having any similar problems with tires on my full size cars or trailers in recent (last 25) years.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
Posted: 27 Feb 2014 at 4:31pm |
I wonder if that difference comes from the older bias tires vs. the newer radials. Better sidewall strength?
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 01 Mar 2014 at 11:28am |
I live in a community that has several rv parks and live in a area one road in and out. I've seen a lot ov shall I say interesting stuff and one is flat tires. Some times we hear the flop flop of a flat going by the house,even the music of a trailer running on the rim,mostly on double axel trailer. But sometimes single axel. Other interesting thing such as,wheel bearings smoking,awnings hanging out, and once a forgotten slider. But one thing I know is that I have never seen a tire repaired on the spot, one reason is they are too far gone and almost always the bead is broken. My 50 ft wide driveway is the first wide spot to pull over comming into town.
Moe
Jo and Gary 2010 174 2011 Ford 150 |
Sleepless
Posted: 01 Mar 2014 at 4:09pm |
Perhaps even a bigger factor is the change from the older rusting steel wheels of yesteryear to the modern alloy of today. I used to spend hours sanding the rust off of old steel wheels before they would seal to the bead. |
