Page <123 |
![]() Posted: 25 Apr 2014 at 8:08am |
Just my random thoughts, but I would make sure the load switch on the generator is OFF. Then it doesn't make much difference whether you plug in first or wait until the gen is running. The important thing is don't try to start the gen with the load connected. |
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Always start the generator, let it warm up for a minute or two to a nice, comfortable idle and then plug in your trailer. When it comes time to shut down, turn off the air conditioner and unplug (or turn off) any appliances that are actively using a significant amount of power, and then unplug the trailer from the generator. Give the generator a minute or two to settle/idle and then you can hit the generator's off/kill switch. The idea is to never do anything abrupt. Let the generator warm up and idle down. Equally, don't expose your electrical equipment to unnecessary surges/brownouts. For example: make sure that the air conditioner is turned off when you plug-in the r-pod, and make sure that its turned off before you unplug the r-pod. Small power drains, like the microwave or television being plugged-in but turned-off, are fine. I do suggest unplugging laptops or expensive electronics while connecting/disconnecting your trailer from any power supply.
techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
I have a long-time thread around here discussing smaller options. The best solution I had found to-date was the Coleman Polar Cub, but recently read about the Coleman Mach 8 which is 2 inches shorter. Both are 9200 btus, which I feel is exactly where it should be for the pods. The big A/Cs are oversized for the pod's area so they don't dehumidify like they should (since they don't run long enough). The Mach 8 should solve both problems - dehumidification and the ability to run from a smaller genset.
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
I agree 13.5 AC is too big and second your statement that short cycling doesn't dehumidify well.
A 13.5 cools my toy hauler with probably triple the volume just fine even in SC heat and humidity, not uncommon for both to be at 100 in the summer. That RV has a built in Onan 4.0 genset. I've longed for someone to build a slimline generator that would fit mostly under the floor or even on the roof if quiet enough....if packaged properly it would be no larger than the AC. In a perfect world we'd have a quiet genset that was no louder than the AC so no one would even know it was running! That might get around those pesky restrictions in most dry campgrounds... |
This is the thread I mentioned above: www.rpod-owners.com/forum_posts.asp?TID=1433
Page <123 |
