Dolly |
Post Reply | Page 12> |
CasaJack
Newbie Joined: 19 Feb 2014 Location: San Gabriel, CA Online Status: Offline Posts: 36 |
Topic: Dolly Posted: 01 May 2014 at 3:15pm |
I need an electric dolly so that I can walk my R-pod down my narrow driveway about 60'. Can anyone recommend one?
Jackdaddy
Boomertype
Senior Member Joined: 12 Jan 2014 Location: Seattle Online Status: Offline Posts: 108 |
Posted: 01 May 2014 at 5:24pm |
I've seen this one used, worked real well.
Here is a video: https://www.youtube.com/watch?v=uqVDxOMrgak#t=81 Not electric and has two gears. |
thadd
Groupie Joined: 06 Oct 2012 Location: Sacramento, CA Online Status: Offline Posts: 53 |
Posted: 01 May 2014 at 6:12pm |
You could go for the high-end solution: http://www.amazon.com/Easi-Move-Trailer-Powered-electric-trailer/dp/B00CD8XIHE/ref=aag_m_pw_dp?ie=UTF8&m=A1AX5CGGC9ZCW5
I personally use a standard trailer dolly (not the powered kind) and it works pretty well. If I were doing it over again, I’d get one with a castor like this: http://www.amazon.com/Tow-Tuff-TMD-1000C-Adjustable-Trailer/dp/B0079YMIFA/ref=sr_1_6?ie=UTF8&qid=1398982303&sr=8-6 As long as your driveway isn’t too steep the hand dollys are probably fine. |
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
Posted: 01 May 2014 at 8:09pm |
We have a electric dolly we would sell you but the freight cost be more than the dolly would cost. It weighs I believe over a hundred pounds. Unless you were wanting a vacation in Florida.
CasaJack
Posted: 02 May 2014 at 10:11am |
Thank you all. I am not sure if the standard dolly can handle my 3400 lbs 182G. I have seen the Trailer Valet but due to the fact that my trailer has the stabilizer brackets on each side of it I don't think there is a place for me to attach it.
Jackdaddy
Boomertype
Posted: 02 May 2014 at 2:52pm |
Trailer Valet is a tongue jack, so it doesn't attach to the frame, it attaches to the tongue, has two gears and will do a incline. |
Podsible Dream
podders Helping podders - pHp Joined: 03 Dec 2010 Location: Hightstown, NJ Online Status: Offline Posts: 571 |
Posted: 10 May 2014 at 7:56pm |
Remember the dolly only supports the tongue weight- just like the hitch on your TV. The deciding factor is if you can get the trailer moving, and then control it when you need to stop. That is when the 3400 lb weight is involved.
Walt
Chris and Walt
'10 RP-171 'Free Spirit' '13 Dodge Durango Crew 5.7 L Hemi V8 |
Mike B
Newbie Joined: 14 Apr 2014 Location: San Diego Ca. Online Status: Offline Posts: 20 |
Posted: 14 May 2014 at 10:45am |
Here's another one that you may like and one that I'm thinking of.
Power Movers Model AC 5 or AC6. |
CasaJack
Posted: 14 May 2014 at 1:29pm |
Thanks. I will have a look at those.
Jackdaddy
Posted: 14 May 2014 at 1:31pm |
You know what you'll say when you order one of these and you open the box for the first time?
(see next post)
