  New Posts New Posts RSS Feed: Ticking propane tank
Topic ClosedTicking propane tank
SNO4ME View Drop Down
Direct Link To This Post Topic: Ticking propane tank
    Posted: 13 Oct 2013 at 9:37pm
Originally posted by The Pod Couple
Thanks! I did find our manual and read it. After waking up the panel with a gentle touch, putting in the code along with the unlock button, it gives a long beep, which if I understand correctly could mean the batteries are low or I've put in the wrong code. My husband is having a go at it now.
The problem with having a new trailer is that it makes us want to be retired. For me that's still five years off. Wink My mother tells me not to wish my life away. I'm trying, I really am.
Hmmmm, I have the same problem but my problem concludes in about 1 year, 8 months, 3 weeks.....................Wink
We're big into snowmobiling and I've never been this disappointed to see the warm weather leave but I've always loved fall, (my second favorite season) .
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
The Pod Couple View Drop Down
Direct Link To This Post Posted: 13 Oct 2013 at 10:18pm
I actually have 2069 days until retirement. Who's counting though, right! Tongue I have an app on my phone that counts down the days.
Larry &Pat
The Pod Couple
2001 Ford F150
2014 RPod 178
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 14 Oct 2013 at 5:41am
I just calculated: 1826!
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 14 Oct 2013 at 11:10am
Been retired since '97.. It rocks. Especially if you do it early. (I was 37) Smile
On the lock.. If it is accepting the touches, but giving a long beep, Batteries MAY be low. You MAY have reset the code to the factory default. You MAY be entering the numbers to fast. You MAY be entering the numbers to slow. Your manual should give you the default combo, and tell you how to reset it, and tell you how to set a custom combo.
Pinging regulators have happened, it's a warranty thing.
Riverrat View Drop Down
Direct Link To This Post Posted: 09 Apr 2014 at 4:59pm
So I'm wondering how you resolved the issue with the keyless entry? We are having the same issue right now Ouch
GlobeTrotter View Drop Down
Direct Link To This Post Posted: 07 May 2014 at 1:52pm
We have a 2014 177 and am experiencing the pinging regulator.  It seems to work OK but I ran out of propane using my heater a lot (or so I thought), went to refill it and found that it was still half full.  Evidently, it did not empty.  Was going to have the regulator replaced but decided  to add a second tank and a dual regulator.  Hopefully that will solve the problem.
Podding from Montana and loving it!
Direct Link To This Post Posted: 07 May 2014 at 2:35pm
It still sounds like you need to get that other regulator replaced.  It is fairly cheap.
bmkparshall View Drop Down
Four months after a new 178 purchase our "keyless" batteries were dead. They were an off brandWink
B MK Parshall
2016 Silverado 5.3 V8 and R-178 Poddler
Direct Link To This Post Posted: 07 May 2014 at 3:38pm
Ok...
The battery life will be kind of short with those, off brand batteries or not, because that keypad is always "on".. waiting for a touch..
