Towing with a Honda |
Post Reply | Page <1 2345> |
wildfire305
Groupie Joined: 22 Jul 2014 Location: Erlanger, KY Online Status: Offline Posts: 85 |
Topic: Towing with a Honda Posted: 05 Aug 2014 at 5:06pm |
The company that makes scangauge said that the transmission temperature was not available in my 2004 Odyssey.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey 2015 RP179 "73b" OLD 2005 Viking Saga 2480ST popup |
Budward
Senior Member Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Posted: 05 Aug 2014 at 5:49pm |
They say that on my Toyota also- but I found a way with the Torque android app and some smart people on a forum that figured out the sensors and shared the info
2014 179
CharlieM
Posted: 05 Aug 2014 at 6:09pm |
The ScanGauge company doesn't always know what the individual autos provide. On my Toyota, and as I remember the Pilot too, I had to get the info from the Tacoma and Pilot user forums. Do a search for the forums, then search them for ScanGauge and/or transmission temperature.
Puck Podders
Newbie Joined: 14 Jun 2014 Location: Baltimore Ont Online Status: Offline Posts: 38 |
Posted: 05 Aug 2014 at 6:37pm |
We picked up our 178 in June and it has been on four trips behind our Rav4 V6 Rated 3500. We use a WDH with sway bars. It works ok but just bought a GMC Sierra so I can relax and just go. Plenty of power and mental peace. Want to hit the coast and mtns so now it is possible with no white knuckles.
Rick & Wilma
'Hairy' Gracie 2015 178 GMC Sierra |
fwunder
Posted: 05 Aug 2014 at 7:05pm |
I think they are correct for the Odyssey. "Transmission Temperature is a manufacturer specific PID" and doesn't appear to have been discovered. The Toyota forums are really active with this stuff. Looks like for Torque (Android) or Engine Link (iPhone), the following will work for 4Runners or Tacomas from 99 forward to 2014. At least that's what I understand... This for the transmission pan temp: Header: 0 PID: 21D9 formula: ((((E*256)+F) * (7/100) – 400)/10) Min value: 0 Max value: 300 Name: Trans Fluid Temp 1 (...or whatever you want to call it) Unit factor: °F This one for the converter outlet temp: Header: 0 PID: 21D9 formula: ((((G*256)+H) * (7/100) – 400)/10) Min value: 0 Max value: 300 Name: Trans Fluid Temp 2 (again, whatever you want to call it) Unit factor: °F I ordered a Elm327 WIFI Wireless OBD2 Scanner so should be able to confirm those codes (for Toyota) in a couple of days. Good luck with Odyssey. fred
Posted: 06 Aug 2014 at 8:45am |
I checked the Interceptor website and they don't support Honda at all, due to the manufacturer-specific codes. Unfortunate - we have an onboard network across all brands but one brand doesn't want to play ball.
wildfire305
Posted: 06 Aug 2014 at 10:04am |
Honda is a lot like apple. I've had things fixed on the van that I couldn't do myself any cheaper just buying the part. Flat rate I guess. And proprietary computer codes so only factory authorized places can fix it. But they have always been proactive about warranty work because they know only they work on the car. I have never had to say "isn't that covered by the warranty?". I have picked up the car and been presented, unexpectedly, with a bill for $0 because they found a way to warranty it. Mind you this is on the second owner factory certified four year extended warranty. I bought the car used. Most dealers' extended warranty stuff is totally BS with high deductibles, but not Honda. Okay, done having my fanboy moment. I probably won't get to know the transmission temperature unless I put an in line analog gauge in.
Budward
Posted: 06 Aug 2014 at 10:31am |
As a counterpoint- I had a 2003 Pilot that developed trans trouble at 80,000 mi. Changed fluid more often that recommended and never towed anything over 1000 lbs and I had the trailer tow package!
Now Honda knew there were issues with this trans in 2002-2003 Odyssey's and Pilot's. They even had a "recall" to add a jet to cool an overheating gear. Didn't matter, thousands of these transmissions failed early. They wouldn't help other than to say give us $4000 and we'll put in another just like it that will also fail! Had an Accord before that they extended the warranty to 100,000 miles because the transmissions were failing. Big sign- get rid of the car before 100,000! My dad had an Odyssey of the same vintage that was on it's third transmission... he didn't keep it long after the warranty expired. So- I'm done with Honda. They use a transmission design unlike anyone else's and have too many issues for an otherwise superb line of vehicles for me to risk it again. I've never understood why transmission design has lagged engine design. I've never lost an engine but I have bought several transmissions over the years..... |
2014 179
Posted: 06 Aug 2014 at 12:38pm |
I had a similar experience with Chevy. In the late 90's/early 00's they used a 6-cylinder in multiple products, I had a Venture. On all the engines at around 60,000 miles the lower intake manifold gasket would rupture internally, sucking all of your coolant into the oil without a drop on the ground to give you warning. I happened to check my fluids within a day or two of it happening to us, so I was able to get ours fixed before the engine self-destructed (which is how most people found out). Didn't do us much good, it threw a rod at 94,000 while pulling our popup home. At least it happened a half-hour from home instead of 3 1/2 hours away.
I think the replacement gasket cost me $800+, most of that labor since the engine had to be basically pulled. It was easy to figure out this was a problem across the engine line with a few searches on the internet showing thousands of complaints, but GM never had a recall. Counterpoint for Toyota, we bought a used Sienna to replace that Venture and the transmission developed a fairly minor problem (stuck relay) not long after we bought it. They replaced the whole thing under warranty, at their insistance. I figured they would just open it up and replace the relay.
Budward
Posted: 06 Aug 2014 at 12:57pm |
Oh yeah BTDT with manifold coolant gasket on Ford 4.0 V6 in a 98 Mazda Pickup. Luckily FelPro came out with a much improved gasket set to hopefully stop the problem from re-occuring. Son is still driving it at 255,000+ miles.
Did all the work myself, except for machine shop time to mill heads flat (it had been overheated) and do a valve job while I had them off. Still cost me $800 Speaking of lucky- we got home from a 5,000 mile trip out west and back with our 86 Ford Club Wagon and Coleman Popup back about 1990...trans went out 2 days later. Often wondered what I would have done if it had been 2-3 days earlier especially with two small children. |
2014 179
