Outside Shower Idea |
Post Reply | Page <12 |
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Topic: Outside Shower Idea Posted: 23 Sep 2014 at 4:15pm |
We have a green two headed connector that we put on the campground water faucet one side goes to the camper city water and we connect a hose to the other side to wash of sandy feet or whatever.
Posted: 23 Sep 2014 at 5:39pm |
I always put a Y on the city water connection, too, but some times that water is just too cold.
Leo B
Posted: 23 Sep 2014 at 5:47pm |
Cold is a mountain stream with the spring melt........campground faucets are all luke warm compared to that!!
Or stepping through a hole while ice fishing!!
Posted: 23 Sep 2014 at 9:46pm |
lol
Seanl
Senior Member Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
Posted: 24 Sep 2014 at 8:47am |
I was thinking about doing this. I thought that I could put quick disconects on the low point drains and on the end of the shower lines to facilitate quick setup and teardown.
2McPods
Groupie Joined: 20 Aug 2014 Location: Pittsburgh,PA Online Status: Offline Posts: 67 |
Posted: 24 Sep 2014 at 9:13am |
We have the 2015 171 and it came with an outside shower that we use to clean the castiron skillet after cooking on the fire. We've also used it to spray mud of shoes or anything else. |
Everything Happens 4 A Reason
Pat & Viki McCartney 2015 171 {2McPods} 2014 F150 Pittsburgh, Pa |
2McPods
Posted: 24 Sep 2014 at 9:27am |
Doug, That's the exact spot our 2015 171 has the outside shower. Great job, it looks factory installed By the way how did you get your photo in your signature?
Posted: 24 Sep 2014 at 3:04pm |
Unfortunately it isn't easy.You need to get a picture sized just right. That took me multiple tries (upload, too big, resize, upload again). Then go to Member Control Panel at the top-right of every page, then File Manager on the left, then File Upload on the right. Once the picture is uploaded it will provide you a link to that new file, on the right. Right click on that link and Copy it. Then look for the tabs near the top, one of them says Profile. Once you are there scroll down to Signature. Then you need to enter the "BB Code" to create the signature you want. Below is a copy of how the code looks for my signature. NOTE I have added an extra space just after each [ bracket and an extra space just before each ] bracket so you can see the code, otherwise the system would interpret the code and it would look exactly like my signature! So make sure to remove the extra spaces if you use my signature as a template for your own. You can also look up BB Code on the net for more examples of commands you can use.
Doug ~ '10 171 (first pod in MD) ~ [ URL=http://www.rpod-owners.com/forum_posts.asp?TID=1723 ]Pod instruction manual[ /URL ]
[ IMG ]http://www.rpod-owners.com/uploads/217/rpodandsuburban2.jpg[ /IMG ] |
