Fresh Water Tank Winterize |
Post Reply | Page <1234> |
Topic: Fresh Water Tank Winterize Posted: 09 Oct 2014 at 1:53pm |
Welcome. As mentioned, the bypass valves will be on the rear of your water heater. Locate the WH on the outside of the pod (large metal grate) and then you'll know where to look for it inside.I wouldn't worry over the anode rod. It may not be shot, they can be hardy. After 4 years I replaced mine even though it was barely worn. Even if you need a new one they are cheap.
heyfly
Newbie Joined: 18 Jul 2014 Online Status: Offline Posts: 6 |
Posted: 09 Oct 2014 at 2:58pm |
We have a 2015 R-178 and loving it. I found the valves under the bed. The only valve under the sink was the one for pumping the antifreeze. I moved the mattress to the dinette side and will leave it there until spring.
This forum and youtube makes us all experts (in our own minds!) |
2015 R-178 TV Chevy 1500 Silverado. Wife and I Retired Jan 2014
Podster
Posted: 09 Oct 2014 at 4:16pm |
"I found the valves under the bed."
Ok, well I have a R-178 as well and although I have not winterized as of yet, I do recall the service tech, during my walk around check out, pointing out an access panel within the rear storage compartment, heater side (curb side). Should be just 4 screws to pull the panel and the valves should be right there. I think it's the R-179 that requires you go in under the mattress. Anyway, enjoy your R-178 and HAPPY RETIREMENT!
wildfire305
Groupie Joined: 22 Jul 2014 Location: Erlanger, KY Online Status: Offline Posts: 85 |
Posted: 10 Oct 2014 at 12:56am |
I have the 179 and I am an average sized person (6' 200 pounds). It is difficult to get to that access panel under the bed. A bigger person would have to remove the mattress and plywood to do it. When the furnace is running, you can't put anything under there in the storage area at all, way too hot.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey 2015 RP179 "73b" OLD 2005 Viking Saga 2480ST popup |
kandk920
Newbie Joined: 11 Sep 2014 Location: Omro, WI Online Status: Offline Posts: 12 |
Posted: 12 Oct 2014 at 8:51pm |
The water heater bypass on the 2015 178 is DEFINITELY under the bed on the left(slide-out) side of the camper. The panel with the 4 screws is located under the sink and are to get to the intake bypass to draw antifreeze into the system directly from the bottle.
2015 R-Pod 178
2008 Town & Country Fox Valley, WI |
Podster
Posted: 13 Oct 2014 at 6:53am |
"The water heater bypass on the 2015 178 is DEFINITELY under the bed..." |
Cliff & Raelynn
wildfire305
Posted: 19 Oct 2014 at 7:59pm |
As a plumber and after inspecting everything while winterizing, I ended up putting a gallon of antifreeze in the water tank because I didn't want to take any chances. There is a loop on my intake hose and that will hold water. That flexible hose (not pex) probably wouldn't break even if it did freeze.
Do I need to get all the water out of the heater? I noticed with the anode removed it still held about 3/8" in the bottom. I could try to suck it out with a bit of hose if I need to. Speaking of anodes, my anode already looked bad after being in service three months. Stayed in it a total of 20 nights during that time and I drain between uses. Must be the water I guess. Anyone else from greater Cincinnati experience that? |
Posted: 19 Oct 2014 at 8:29pm |
Don't worry about the water left in the WH.
marwayne
Posted: 20 Oct 2014 at 12:44am |
I do siphon the last bit of water out of the HWT. My anode after 4 years has about 75% of wear left. I don't want to brag, but we do have one of the best drinking water in all of North America.
ToolmanJohn
Posted: 20 Oct 2014 at 6:30am |
Personally I don't allow any anti-freeze into the hot water heater. I was told that the anti-freeze can attack the electric element and anode rod. That was what the bypass valves are for , to keep the anti freeze from entering the hot water heater.
I just drain the fresh tank and hot and cold lines then close the low point drains, bypass the water heater, use almost 2 gallons sucked into the winterization pickup hose for the hot and cold lines (open both valves on the kitchen sink and bathroom sink and run the toilet until pink flows out) and also pour into P-Traps. Done. In the Spring, I drain the anti-freeze from the low point drains, I fill the fresh tank with about 3-4 cups of chlorine bleach, fill with city water, the run out the hot and cold lines until clear of anti-freeeze. Let sit for a day. Then drain the entire thing again. Fill with fresh and drain again. The very last thing I do is open the hot water heater bypass valves. I don't want chlorine in the hot water tank, that is bad for the anode rod and heat element. It takes a while but this is exactly how it was relayed to me by the owner of the RV dealership I bought my first TT from (not an R-Pod), and he was my high school buddy. He took over the dealership from his uncle. He said just blowing out the lines is OK, but in rare cases, the way a trailer is made can affect how much water remains in certain lines/areas/low spots. There may be some small amount of water left over, just how much is not known, so it's safest to use anti-freeze so thinks can't crack.
