r-pod Airflow |
Post Reply | Page <1234> |
Guests
Guest Group |
Topic: r-pod Airflow Posted: 15 Oct 2009 at 5:13pm |
Thanks Outbound. This confirms my experiences. I can "feel" when someone is behind me, within this turbulent area - it causes me to slow down, as if I were gently on the brakes. I'll pretend to be an armchair engineer and say that I think the spoiler is almost the right idea. I'm inclined to think that an air deflector, which would be high on the Pod and direct air down the rear of the Pod might work better. It could grab some of the "clean air" and direct it into the low pressure area at the rear of the pod. It looks like the low volume of air from underneath the vehicles is trying to (inadequately) fill this area. The faster we go, the more we are "sucked backwards" because of the low pressure. The air flowing over the top of the Pod should be moving very quickly (like over the top of an airplane wing). The Pod is "blunt" enough in the rear (unlike an airplane wing) that there is considerable turbulence. It makes sence (to me) that the lower mounted spoilers would have no effect. The higher mounted spoiler, it would seem, would push the turbulence back, but create an even bigger low pressure area. An air deflector, forcing air into the low pressure area, might be the answer. It will produce some drag, but, I'm thinking not near as much as the big low pressue area behind the Pod. Is it possible to try something like this on the modeling software?
Posted: 15 Oct 2009 at 3:14pm |
We've been camping a lot at Codorus State Park lately (SW corner of York County). Been there the last 3 weekends, next one we're taking a break, then the next 2 weekends we'll be back again. We wanted to get more camping in before the end of the season but our girls have practices and games every weekend right now. Then I remembered that Codorus has a campground and its 5 minutes from where they practice. Solved that problem!
Guests
Guest Group |
Posted: 15 Oct 2009 at 1:22pm |
techntrek I'll wave at you the entire trip I'll be so glad to get the 177. I'll be going up I 81 near Harrisburg so you will have to get your binoculars out to see us. I plan to thumb my nose at the State legislators as I go by too.
From what I'm seeing there are enough folks in and around PA to have a R-Pod Jamboree sometime in the spring. Lots of good camp spots in PA. We have several close to us here in the North Central part of PA. |
Posted: 15 Oct 2009 at 12:28pm |
Sandpiper, if you'll be driving near Shrewsbury, PA, wave as you go by. We're about 10 minutes south.
Outbound - doh! Thanks for the still pics but most image hosting sites are blocked @ work, too. Since I have a high speed connection via my phone I've been considering buying a cheap laptop to leave at work. Others here have done the same.
Guests
Guest Group |
Posted: 14 Oct 2009 at 11:39pm |
I went back to the web site and reread the instructions. Duh !! Found the instructions to produce the bit map and there in lies the problem. I don't have my 177 yet so can't photograph the combo to produce the bit map. I'll postpone the project until I get back from picking up the r pod. I'll get some good photos while we camp our way through OH, TN, VA, WV, MD and PA.
Thanks for your response and I'll be back to pick your brains at a later date. |
Guests
Guest Group |
Posted: 14 Oct 2009 at 9:45pm |
Sandpiper, to create the silhouette, I took a picture of my Tribute & r-pod hitched together and then loaded it into photo editing software. I used paint.NET because its relatively simple, but PhotoShop or GIMP would be the most robust choices (paint.NET and GIMP are both GPL software). I then erased the background (white) and coloured-in the foreground (black); I also drew in a "road" at the bottom of the image. In total, it took about 10 minutes to prepare the image. I then saved it as a 24-bit bitmap file.
The "more info" page on Flow Illustrator goes into some depth about how to prepare the bitmap file and provides more information about the available parameters. When you're ready to run the simulation, go to Flow Illustrator's "movie maker" page, select bitmap, upload your silhouette, change the parameters as necessary, click on submit and then click on "get the movie" and wait for it to process. |
Guests
Guest Group |
Posted: 14 Oct 2009 at 7:48pm |
Outbound
You have piqued my interest now so I would like to have more info on how you did what you did. It's been many years since I've played with finite element analysis programs but this seems much simpler. Questions 1.) how did you develop the outline of your vehicles. I want to try this with my pickup. 2.) I looked at the web site and failed to find any instructions for submitting a shape, nor establishing things like boundary conditions , air velocity, shape size, re numbers etc. Can you help me out ? |
Guests
Guest Group |
Posted: 14 Oct 2009 at 7:29pm |
This time, I tried to move the spoiler around.
Spoiler in a low position, just over the spare. This really had no effect whatsoever. (Still image for the YouTube impared) Spoiler in a mid-position - just above the rear window. It does move the turbulence back a few feet, but I have no idea if this is a good thing. (Still image for the YouTube impared) |
Posted: 14 Oct 2009 at 11:05am |
Unfortunately the videos are blocked here at work - how did the airflow look with the spoiler? Did you try different size spoilers, and at different heights?
Dang good idea. Would change "the look", but practicality has to come first IMO.
Guests
Guest Group |
Posted: 14 Oct 2009 at 6:25am |
I cleaned-up the image a little bit. Here's the improved version:
Proving my lack of engineering skills, I added a spoiler about 6' up on the rear of the pod: |
