Have You Done Any Mods? |
Post Reply | Page <1 2526272829 52> |
Harry
Newbie Joined: 10 Jul 2014 Location: Nova Scotia Online Status: Offline Posts: 38 |
Topic: Have You Done Any Mods? Posted: 22 Jul 2015 at 8:25am |
I'll try this again.
Thank you for these photos. Is this holder made of regular ABS drain pipe? Or is this a dedicated product? Is there any provision for ventilation so the sewer hose inside can dry?
2013 R-pod 176T
TV: 2013 Honda Ridgeline 3.5 L 4WD |
Q7-retired
Senior Member Joined: 26 Dec 2014 Location: Pittsboro, NC Online Status: Offline Posts: 100 |
Post Options Quote Reply Posted: 25 Jul 2015 at 8:58pm |
We've done a number of mods where other folks have led the way. Right now we are experimenting with the U-shaped dinette. After strengthening the structure supporting the seats, cutting plywood down a bit and velcro-ing back cushions to the walls, we turned our attention to the back. Since only I and my darling wife (just had 33rd anniversary of our First Date!) camp in our 179, we took off the back cushions and laid washtubs along the seat. The relatively loose retaining cord keeps things in place but still permits some access to underseat storage. We like the idea of living out of buckets!
We probably will put a small shelf with rails above the valences. |
Best regards, Jim
2015-RP178 TV 2015 Audi Q7 TDI and 2017 Ford F150 At home in "Our Pod" |
kindell
Groupie Joined: 10 Jul 2015 Location: No California Online Status: Offline Posts: 61 |
Post Options Quote Reply Posted: 30 Jul 2015 at 3:24pm |
why change out microwave oven? Mine is a convection/grill/microwave and I don't understand changing.
Art & Kindell
Cooper the Super Dog 2017 Keystone Bullet 265 2013 Chevrolet Silverado 1/2 ton Former 2015 RPod 179 |
kindell
Post Options Quote Reply Posted: 30 Jul 2015 at 3:44pm |
Does anybody have the 179 that they have done mods to? Is there space under the banquette that can be converted to storage? Need some place to store shoes so not always tripping over them. Using baskets under bed for other storage.
Art & Kindell Cooper the wonder dog 2015 R179 2015 Nissan Frontier SV 4x4 |
Art & Kindell
BmacZhillsFL
Newbie Joined: 30 Jun 2015 Location: Fl Online Status: Offline Posts: 7 |
Post Options Quote Reply Posted: 30 Jul 2015 at 4:26pm |
Hello we have a 179 and found storage under the cushion on the right hands side facing the unit
2016 R-Pod 179
2014 Chrysler town and country v6 |
dropkick
Newbie Joined: 17 Jul 2015 Online Status: Offline Posts: 18 |
Post Options Quote Reply Posted: 13 Aug 2015 at 2:29am |
I did almost those exact same mods! Put in that same kind of breaker tho it's inside the box. Don't really need an external cutoff switch but now it's there if needed, plus now there's an actual protection device at the batteries, not 6 feet downstream. Have two batteries. Were they wired for proper parallel balance? Of course not! Cleaned up that mess of a wiring job underneath too. Ours was just hanging down a good 8 inches waiting to be snagged on something on the road or even driveway, taking the brake wiring with it. Great QC there. Also repurposed that auto reset breaker to protect the 12V line to the tow vehicle (tho kept the brakes unfused as is factory, just whatever's in the truck protects that line). And it connects the 2 cables together until I run a bigger one. I'm going to relocate all that junk eventually. No need to expose any of that to the elements. Yeah the grounded paint and multiple adjacent ground points were a bit of a head shaker too. Not to mention all the extermely loose ground/negative wires on the busbar under the seat. One of the 6ga just fell out by touching it. Ugh! All solid now! |
Jules
Newbie Joined: 12 Mar 2015 Location: WI Online Status: Offline Posts: 38 |
Post Options Quote Reply Posted: 28 Aug 2015 at 4:51pm |
best thing yet is a slide out shelf in the cabinet under the stove. Now we can actually get at pots and pans without unloading the entire cabinet.
Memory foam toppers on the bunk mattresses is also a must do.
future holds drawers under the bunks. Since we are used to tent camping, this is still pretty glamorous to us. 2016 172 |
Grandpa Hiker
Senior Member Joined: 04 Jan 2015 Location: Martinsville, V Online Status: Offline Posts: 143 |
Post Options Quote Reply Posted: 15 Oct 2015 at 6:04pm |
I decided to install piano hinges on the plywood under the mattress of my 179 to make it quicker & easier to access the water pump, etc. for winterizing. Imaging my surprise & joy after removing the plywood panel & found a good size unused space between the outside storage compartment & the wardrobe cabinet.
Just days before I had bought a 2 ton floor jack from Wally World and was trying to figure out where I could store it. The jack fits perfectly in this new found space. |
Rob & Becky
2014 Ford Explorer 3.5 SOHC V6 2015 R-179 Pod aka Piddle Pod "Life is not about waiting for the storms to pass, it is about learning to dance in the rain!!" |
Jobwabe
Newbie Joined: 15 Oct 2015 Location: Susanville Online Status: Offline Posts: 17 |
Post Options Quote Reply Posted: 15 Oct 2015 at 7:20pm |
On our 177 pod I added- a 250 lb hitch weight rated towing tension bar 1/8 in plywood "floor: for A frame to keep wood blocks, hitching accessories. And for air flow?? propane gas gauge. Replaced battery with 2 golf cart (true deep cycle)6 volt, in-series, batteries. Added 2 100W Solar Panels on roof-1 ahead of AC unit, 1 behind (over cut-shorter shower vent). Rear view night vision camera mounted in spare tire frame plate. Bike rack mounts on spare tire. Made back stabilizers removable for off-road uneven ground situations-they're kept in rear storage. 3" foam topper on bed. Replaced above bed blinds with curtains. Wired in 12 volts to 1000W DC/AC converter twin socket in order to run laptop(or whatever) from DC and I keep it in cabinet above entertainment center. Trying to figure out a way to add my 2 battery operated portable speakers to this Intertek 9901321 DVD player without opening it up and splicing! Going to wall hook hang them on both sides. Any help? Kitchen area- wall hung sponge holder, paper towel holder to opposite walls. Will be adding a wall mount sink cover holder. LED light bulbs throughout. Added thin flexible fiber-plastic-white- (looks like the stuff you see mounted on some gas station or other public restroom stall walls) underneath trailer carriage frame to change all frame or water tank vertical 90 degree angles to approximately 35 degree angles and silicon-ed around all the fiber-board gaps. Then boarded gap between water tanks and foam insulated both sides of that gap. All this to created good aerodynamics under carriage. This gave me a minimum of 22 percent increase in documented gas mileage! Using my 3.3 Litre (6 cylinder) '05 Toyota Highlander with 2 tranny coolers and 1 crankcase oil cooler I originally documented getting 9.5-10.5 mpg pulling unloaded and dry trailer on flat land with no head winds at 55 mph. Now with water tank 2/3 full stocked with all gear, including a generator, tools, I get 12.5 mpg -sometimes better, in same speed and conditions!! |
Post Options Quote Reply Posted: 15 Oct 2015 at 8:29pm |
I'll be interested to see the long-term mpg results! Sounds like you did what the big-rigs do.
